> > > >Tim, > > > >I noticed the uk in your address and assume you are in the UK. > > > >Be careful when ordering Video’s from the states (or anywhere abroad), as the > >NTSC video system used there is not compatible with your UK PAL video. If you > >do order specify a PAL version of the tape, which ther may or may not be able > >to provide ! > > > >A good video specialist could convert an NTSC video to PAL format, but this > >is going to cost you ! > > > >James. > > Thanks for the advice. I didn’t realise this. Perhaps this caution is worth > putting in the FAQ too?
Done.
Beirne
Beirne Konarski | Subscribe to the Unicycling Mailing List bkonarsk@mcs.kent.edu | Send requests to unicycling-request@mcs.kent.edu “Untouched by Scandal” |
Unicycling Web Page:
| http://nimitz.mcs.kent.edu/~bkonarsk/
> >Be careful when ordering Video’s from the states (or anywhere abroad), as the >NTSC video system used there is not compatible with your UK PAL video. If you >do order specify a PAL version of the tape, which ther may or may not be able >to provide ! > >A good video specialist could convert an NTSC video to PAL format, but this is >going to cost you ! > >James.
This is not strictly true. Some of the VCRs available today CAN play both
formats. It is usually the higher in the range or more expensive models. It is
worth checking to see if your VCR has this capability if you intend to aquire
videos from abroad. You may not need the conversion after all.
Panasonic and Mitsubushi are two manufacturers that I know definately make this
type of VCR.
