Wow, doing great! That location looks like an awesome place to learn how to ride - the hand rail seems to be a great height. In no time you’ll be steering away from it and riding all over that court.
Good job and nice video.
I see that the rail you are using is about the ideal height.
I think I have explain this before, but is always worth repeating.
(Somebody should have told me when I started…but…nahhh)
When a fence or rail is too high, then it helps too much.
However, the lower the rail the “less help” is better.
It allows upper body freedom/twisting and also lower body the freedom to twist/learn.
Something like a tennis court net or about 4 ft above ground is perfect.
As, long as your arms are extended or slightly bent this “takes away” leverage.
You don’t need that as you practice and get better. keep on.
And here’s a tiny bit of footage of the youngest daughter.
Unfortunately the camera battery was empty so I could only shoot very short clips and then the camera would shut off.
