Hey everyone,
i recently bought a BRAND NEW try-all fluro/neon green drilled rim for my uni but ended up getting my other rim powder coated for free with my frame so i will not be needing it any more. i am looking for £40 for the rim posted
description-
"Stylish looking rim with holes cut out for a distinctive look. As used on the Koxx Devil unicycles.
Double walled rim with braking surface. This rim is really wide to give your tyres a wider profile and more contact and grip. This rim is as wide as the Onza “Hog” rim or the Kris Holm 2007 trials rim but with bigger holes cut out and no eyelets to save weight.
also my practically BRAND NEW tryall seatpost that came with my uni but was only used for a few days because a bought a cro-mo nimbus one. i am looking for £15 posted
it should fit a kris holm unicycle as well, but not a nimbus frame
description
Replacement aluminium seatpost for Koxx unicycles, 250mm long hard anodised in Black with Try-All logo with reinforced where the top meets the plate.
27.2mm diameter same diameter as Kris Holm and Onza unicycles (Koxx unicycles come with 29.4 - 27.2 shim). Shorter than the Kris Holm or Onza reinforced aluminium seatposts so only weighs 170g, fits all saddles with standard 4 bolt fittings.
the only marks on it are where the bolts tighten to fit it to a saddle
pictures
rim
rim again
rim again again
tryall seat post
yea should be able to if you are fully interested then let me know and i will work out postage costs (you will have to tell me where bouts you live and i will probably respond faster if you PM me thanks.
it is a normal 19" trials rim with 36 spoke holes so would work with a kh hub etc…
you may want to check with unicycle.com just in case but i am 95% sure.
if anyone is actually interested in buying an item then as i said before PM me
