Hopping - Standing on the pedals, bouncing as if the unicycle were a pogo stick. One foot riding - One foot on a pedal, the other foot rests on the frame. Seat in front - Instead of sitting on the seat, it is held out in front with the hands. Wheel walking - Sitting on the seat, you walk backwards on the top of the wheel, propelling the unicycle forwards. One-footed wheel walking - As wheel walking, but you push the wheel with one foot, sliding it backwards to push again. Gliding - Sitting on the seat, one foot rests on the frame, the other touches the wheel as a brake. The amount of pressure adjusts the amount of breaking. This is started from speed, or can be performed downhill where a constant speed can be maintained. Coasting - Both feet resting on the frame. The arms are extended forwards and upwards, then waved to keep balance. This has to be started from speed, and downhill is not recommended.
Back when that was considered a good enough trick to name it was called a fastforward and a backwards version was called a rewind. But now their just called Revs. And yeah their called ETs in bmx. (Referance to the movie ET. When they fly past the moon and pedal in mid air.)
No, a crankflip is when you kick the pedal. take your feet off and let the cranks do a full revolution, a rev (I think) is when you jump and your feet never leave the pedals, but the cranks do a full revolution.
I’ve got a question about pedal grabs and crank grabs.
I often hop up onto an object using either a pedal or crank grab, but I’m not actually sure which I use. I seem to be using both. Is there really much difference between them? I mean, I know that it is much more stable on the crank rather than the pedal, I just wondered whether there really needed to be a differential between the two.
Does anyone find one or the other better or think that I’m completely wrong by saying any of this?!
Would somebody like to write a short, or long, list of tricks such as flip tricks and spin tricks and so on. Or people could just add tricks as they go. Like favourtie tricks. It’d be cool if we had a thread that people could refer back to when learning new tricks.
If you write it in the format of:
eg. 180 unispin - turning the uni 180degrees whilst jumping above it, then landing back on the pedals with the uni facing backwards.
whats a shifty?
whats the difference between a pedal/crank grab and a pedal/crank stall? if there is…
what is the difference between 180 flip and a hickflip
what is a hoptwist
what is a smallspin, bigspin, huge spin, giantspin
whats a sexchange?
whats an x-up
whats an out flip and whats an inflip?
