You’ve probably finished this debate, but that’s a lot of posts that I’ve read in one go that I’ve wanted to talk about, so I’m going to have to catch up a bit.
Firstly, potential energy can be understood easier if you consider a ball (for example) rolling down a hill. At the top of the hill it has high potential energy, and no kinetic energy. (I’m using sea level as a reference here. It makes sense, 'cause it can be sued for pretty much every situation. Unless anyone unicycles underwater. But in that case you have buoyancy as well, which confuses everything. And I’m talking about kinetic energy as well, because it helps. Honestly! Anyway, I had a point once, what was it?) Right. If you let the ball go from the top of the hill, it rolls down the hill. It clearly gains kinetic energy, because it speeds up. Energy cannot be created or destroyed, so the kinetic energy has to have come from somewhere. In this case it has come from the potential energy. The increase in kinetic energy is equal to the loss of potential energy.
The main point in my original post was that on a treadmill you don’t gain potential energy or kinetic energy, but you have to do work against the motor, which is moving the belt in a way that would pull you downwards, thereby reducing your potential energy, if you stopped pedalling. On a treadmill, you aren’t doing work to increase your potential energy, you’re doing the same amount of work to stop it being decreased.
The other bit was about travelling in a horizontal direction. Here, finally, we can forget potential energy. Here, newton’s law of force = mass * acceleration is what you want. That means a force is only required to change the speed of something. So in horizontal travel, you exert a force when you start to increase your speed, but then stop exerting the force when you reach a constant speed. “But it bloomin’ well feels like I’m exerting a force”, I hear you shout. This is true, because you have a constant frictional force opposing you. The force in the newton’s thing is actually resultant, or overall, force. The force you exert at a constant speed is equal to friction, so that the total force on you / your unicycle is 0, and there is no acceleration or decceleration. Another way of looking at it is that if there was no friction, you wouldn’t have to exert a force to travel at constant speed. For example, if you unicycled on ice, with slick tyres (which would be pretty impressive) the friction force would be tiny, and you would hardly have to do any work to keep going. However you wouldn’t be able to go anywhere, because apart from the balance thing friction is the only way you can exert a force on the surface your riding on to speed up ort slow down.
Right, I’m stopping now. That’s a bloomin’ long post. I really need to get out more.
P.S. Just to confuse things (even more), the energy cannot be created or destroyed thing falls apart with quantum physics, where you have a scary complicated mass / energy duality thing, but that’s far too complicated, and isn’t particularly relevant. Unless anyone’s considering a fusion powered unicycle. I didn’t really need to say this, but I don’t want anyone else to beat me to it. Not that anyone would do that. Particularly anyone doing computing at york uni. Never.
