The Vee tire Trax monster 36 inch tire, in my experience, was almost unrideable on the road due to extreme camber sensitivity, even at 55 psi. So, with the same tool I used to reshape an older NR (the tread doctor tire groover), I was able to get comparable, positive results. Now, it’s a pleasure to ride both on and offroad.
Do you know how much weight you ended up removing by making it rounder?
Didn’t weigh before and after, but tgere were quite a few bits of rubber on the ground afterwards.
First time I see the unicyclist hanging on a tree instead of the unicycle ![]()
