a friend of mine has an animated picture of a crawling frog, and it has a white background. I’ve been trying to make it have a transparent background, but still animated, and I can’t figure out how to do it… I’ve attached the picture of the one I made to make the background transparent, and my problem is pretty obvious.
does anyone know how to fix this?
I think it looks cool like that
Re: transparent and animated gifs
You need to tell it to redraw everything on each new frame. What program are you using?
I’m using the GIMP.
I’ll look for an option to do that, thanks!
i wonder what happed to Nikkifrog
hmm, I checked, and couldn’t find anything about redrawing each frame on the GIMP…
Jagur, I was wondering the same thing, this is her picture.
You have to do some overdrawing …
IE: Draw over where the frogs last step was
… and use ‘combine’ frames.
So … you need to grab the background color ‘frame’ from this forum.
So, it will ‘look’ transparent here only
(Unless you find another forum with this same grey color)
cuz, you can’t use transparency
I know that it is possible to make .gif animations with transparency, like this picture:
Dismantle that one and see how it works
This is the frog in it’s ‘dismantled form’ using Gimp2
You can see how the the other frames ‘overwrite’
hmm, that’s strange. they all appear somewhat off center. and they don’t have a transparent background in that one. in the GIMP for me, they all do have a transparent background.
That one uses ‘replace’
So the provious frame is erased…? (I don’t know)
test …
Hhah! … it worked !
argh, you just beat me to it!! my other computer has GIMP v1 instead of v2, so it was more confusing. I came to this one, renamed each frame to framex (100ms) (replace)
and BOOM it worked!
danke!
I made this one a while ago. What I’d really like to do is spend the time increasing the frame rate to at least twice this…now that would look smooth.
Don’t worry though, it won’t be used as my avitar.
Andrew
Well that didn’t work…here it is.
lol …
AC … that’s funny …
I can’t help but laugh at your missfortune.
(forgive me?)
That’s okay, I like to laugh at it too. All I got was a bloody nose and a little cut…and a great video!
Andrew
P.S. Your sig. reminds me of something a friend of mine once wrote up on the board at school…
“Nietzsche is dead” - God
I’m right here. And I can’t believe I came back to the forums only to find that someone had STOLEN my frog!
Just kidding.
Nikki (frog)
Now I think I’ll make a post to catch up because I have been gone for far too long.
Busted !
