As the title says, regardless of the kind of riding you want to do, which unicycle is better in regards to the length of their cranks? I hear the 26" has almost 7" cranks for no reason. WHat’s up with that?
The crank length depends on the kind of riding you do. If you want to ride fast on level ground, you want shorter cranks. If you want to go for rides on mountain roads with steep inclines, you may want to get longer cranks. You shouldn’t worry about crank length as much as wheel size, as a different pair of cranks can be had for $20.
Okay, I think I understand better now, thanks.
