Has anyone converted a 20’’ Torker DX into a trials uni? If so, would you have to replace anything but the tire? I am thinking about doing this because it would be cheaper than buying a cheaper trials uni and replacing the hub with a splined one. Also, would wheight be a problem?
The DX uses a standard 20" rim, not a Trials 19" rim. I haven’t found a high-volume tire in the US that gets close to a trials tire. If you’re in the UK you can try an Onza Stick Fingers.
Otherwise you would need to convert to a trials rim. The DX is 48 spoke, I believe most trials rims are 36.
