Can anyone tell me where I can find a hub and crank assembly for my dx 24??
If you are getting a new hub and cranks you can get whatever you want. I would recommend Nimbus hub with KH moment cranks
or you might need a quax because it is 48 hole pattern?
Sorry I ment hub and axel so I can keep the cranks that I have
Depending on what happened it may be available direct from Torker USA through the seattle bike supply. I’ve heard they actually have quite a good warranty.
