Tire widths on wide rims
Nokian Gazza 24x3" on KH47 -> 75mm -> 3.0"
Larry 26x3.8 on LM light -> 93mm -> 3.7"
Nate 26x3.8 on LM -> 97mm -> 3.8"
The Nates sidewall is bulging out here and there if i increase the pressure.
(yes, always far below maximum… :roll_eyes: )
But maybe thats a problem of only “my” Nate.
Has anyone tried a 24" LM with a KH frame?
Yes, there are a few who have and still do run the Marge 24" in a KH24 frame with a 24x3 tire. A search should turn up more specifics but offset adapters need to be used with Magura rim brakes.
Ok. breaks will be no problem since there are disc breaks now.
i just wonder if there is enough clearance(?) for the tire.
might be my next project.. :sunglasses:
If you are wanting to run a large marge on a kh there will be enough clearance
thanks. Yes, i’ve seen some pics of “MuniAddict”. I think he’s got a 24KH with LM.
