Hello,
There have been so many new developments that I figure it’s time to upgrade my stock Coker and get the Ultimate Touring Machine. My criteria for the unicycle are (in no particular order):
- Should be easy to travel with (planes, trains, buses, etc).
- Flexible enough to do large distances on road yet strong enough to do a bit of off-road (distance and bit of technical riding too).
- Lightweight, lower maintenance and strong (so things don’t go bust in the middle of nowhere).
I’m looking at a 29" option and a 36" option. Let’s assume that money is not an issue
The 29" Option:
Frame: 29" Triton. Like Ken Looi’s. (Would those be the lightest (taking strength into consideration) available? Any issues with them I should be concerned with?)
Would a Ti seatpost and handle be any good?
The KH Schlumpf Hub
Cranks: Double-hole Moment cranks in 150mm/125mm length (Would it be possible to get a 110m hole custom drilled or would the holes end up being to close? You do get ISIS cranks that are smaller then 100mm, right?)
Rim:700cx38mm, 36 hole, double wall KH rim
KH Fusion Freeride Saddle
Not too fussed about the pedals, tyre and spokes at this point.
Any flaws with this set-up?
The good thing about this unicycle is that it’ll be easy to travel with. It’ll be very versatile coz I can do long distance on the higher gear, and more technical muni and city riding (Asian cities!) on the lower gear. There are lots of options for 29" wheels. And if I have issues with it travelling in a remote region (like a busted inner tube), parts or make-do parts should be easier to find.
The 36" Option:
Frame: 36" Triton. (Would those be the lightest available? Any issues with them I should be concerned with? The new KH 36"would be a good option too.)
Rim:The Nimbus Al rim. The KH 36" rim will be similar, right?
Tyre: The Nightrider looks good at this point.
Not too fussed about the pedals and spokes at this point.
Hub: I’ve been riding a non-geared UDC hub for a while. I can climb, do flats, a bit of muni etc on it. Do I really need a geared hub? With the lower gear of the geared hub, I can do a lot. So, with the higher gear??? Some people like it. Some people say its only good for certain types of terrain. What types? Is there any problem with the hub in terms of maintenance and durability at this point? Also with the geared hub, I may need a brake while descending hills. I’m not too keen on a brake as it’s more things that can go wrong in the middle of nowhere. So, descending in the lower gear should be ok (for now).
Not as easy to travel with, compared to a 29". Not the best for too much city riding. I really like the feel of the Coker though- feels stable and powerful. Not as many options as a 29" but this seems to be changing.
I think the holy grail of adventure unicycling is to do an unsupported long distance muni tour. Hence, I want my uni to be light, so I can attach my gear to it (that’ll weigh it down) but of course, be strong enough to carry all the stuff.
Thoughts? And if you have answers to my many questions, please go ahead…I’m all ears. Looking to slowly acquire the parts over the next 12 months.
Thanks,
Sid
