Re: Strange Lasco Breakage
>These are my 4th pair of cranks on this uni, 2 >pairs have been lascos, one pair
>was cheap steel ones, and an other pair was some >cut-down MTB cranks…
how did the cut down mtb cranks work out?
how exactly did you modify them?
sounds like neat idea, were they any good?
>This pair of lascos lasted me close to a month, >compared to my first pair which
>lasted me 3 days. I was really trying to make >this second pair last a little
>longer (I didn’t do any drop over 1.5 feet, >although I can hop higher than
>that).
i’ve mannaged to make a set of cheapo steel cranks last about a month, by landing softly and not doing insane dropoffs, every so often i get the urge to do a gap or two and they get a little bit more bent.
the best thing about using cheapo cranks that won;t take a drop is that my wheel walking has improved and so have my uni spins.
>125mm Bicycle Euro Cranks are on the way. Thanx >Roger!
i started out using b.e 125s but after i bent my first set i moved to 150s, i had a spare steel set lying arround and stuck them on to keep me going, and i found that i muchh prefered them, more torque on uphills, more stable to land drops.
and unfortunatly more likeley to bend
so after a couple of sets of 150s i decided to stay out of the pub for a month and buy a profile setup. i figured that i was closeto breaking my hub and that if i broke a couple of hubs then it’d cost me about the same as a couple of suzue hubs and wheel building.
i was going to get the onza hub (which will be cheaper)but it won’t be available for ages.
i should get my wheel back on wednesday, and then i can start doing some daft dropoffs without worrying about the uni dying on me.
ewan.
