It’s not the air resistance that makes it effective, it is the change in the angular momentum that it causes. By the law of conservation of angular momentum your body must rotate in the opposite direction. You would get the same effect if a vacuum.
True. While it might be enough to be useful in a zero-g stillstand, there’d be no point in doing such a thing. But give me a pressurized, zero-g environment with enough room to play around, and I’ll make myself a pair of wings (and a tail, I guess) and fly all over the place in there!
I’m surprised nobody though of that in advance. My dad was part of the “army of engineers” NASA had in the 60s and was involved with that sort of stuff for the Gemini and Apollo programs.
I was going to gripe about rhetorical physics and the futility of getting anywhere without using numbers or equations. But arm-waving about literal arm-waving… Gotta respect that.
From what I read, impulse = force * time = effect/change of momentum. So I’m not sure that’s useful here…
I kinda like that idea/explanation - you can sort of borrow time by falling, then push yourself back up when you’re straight - but I’m not sure how much it explains. I think the later discussion of angular momentum is much more promising…
That’s more like it. So by waving my arms, I make my body rotate. My body would like to rotate about the same center about which my arms are rotating, but that’s not possible because it’s anchored at the ground. Instead, a horizontal force is exerted on my tyre, which is transmitted to the earth via friction (and thus the Earth moves, infinitesimally); and the equal-and-opposite horizontal force pushes back on me, and yes, my center of mass moves.
It has to be rotation, tho - if I just move my arms (say 5kg) horizontally (say 1m), then the equal-and-opposite force would just move my body (say 50kg) back in the opposite direction (by 10cm); I can’t change my center-of-mass this way (tyre friction may stop entire body+unicycle moving by 10cm, and turn it into rotation, plus corresponding counter-rotation of the earth to preserve angular momentum, but I don’t think that ends up moving my centre of mass, unless I rotate my arms rather than just move them across).
That’s now my understanding, anyway. Thanks to all who posted in helping me get to that ;).
