RE: std. skill questions
Tammy,
Questions and feedback on Standard Skill are always useful for us in evaluating
our rules. It’s a hard event to understand without seeing it done (another area
where a hardly-selling-any-copies video would be real useful).
> what does the “c” mean?
C means circle (ride it in a circle). This is found at the top of the Standard
Skills List: http://www.unicycling.org/iuf/rulebook/iufrules/7sslist.html
> sometimes it’s a 7 or an 8 after the trick, is that the level?
This brings up a common problem people have with our Standard Skill competition
event. Sorry about that. For some reason they always try to connect it to the
Skill Levels, and we have not done enough to dispel this common misconception.
The IUF/USA Skill Levels borrow from the Standard Skills List for definitions of
the skills. Otherwise, they are merely a suggested progression of skills for
unicyclists, and have no connection with any competition event. There are no
“levels” in Standard Skill, only point values.
An 8 after a trick means figure eight. I don’t know where you’re seeing a 7.
Look in the Standard Skill Rules area:
http://www.unicycling.org/iuf/rulebook/iufrules/4stdskl.html for diagrams of how
the different figure shapes are ridden.
Tammy’s example, which I will dissect below:
> 22b wheel walk frame between feet -c 4.2
“22b” is the skill or “figure” number. The rulebook calls them figures, but
should not be confused with the “figure 8” you may ride it in. “b” means it’s
a variation with a specific description that separates it from an “a” or “c”,
in this case a circle instead of a straight line. Each figure number may be
used only once in a Standard Skill performance. In other words, you can’t use
22a and 22b.
“wheel walk frame between feet” is the figure’s name. The names try to be
descriptive without being too long. Longer descriptions of each figure appear in
the Descriptions list.
“-c” means you must ride it in a circle, as described in the part of the rules
with the diagram. The circle must be 100% of the way around, and stay outside
the 4m circle line all the way around. It’s best to overlap a little bit from
where you started your circle, to make sure you rode it all the way around.
Otherwise you lose 50% of the figure’s value from your score.
“4.2” is the point value of this figure. Do it perfect and you get to keep the
4.2, otherwise parts of it get chipped away as you make mistakes…
> does that mean split wheel walk?
Don’t split the wheel (save that for the lumberjack competition)! It’s
sitting on the seat (always assumed if not stated otherwise), pushing the wheel
with one foot in front like regular wheel walking, and the other foot on the
back part of the wheel. This trick is more commonly done backward, where the
rear foot has more to do. The rear foot can’t help much going forward.
When in doubt on figure descriptions, read the other figure descriptions to see
if the one you’re thinking of is in there.
> can the seat not touch your body for the seat on side tricks?
That is correct, though it doesn’t seem to state that directly. When in doubt,
look at the figure names:
7. a) seat on side, seat against body 3.0
b) seat on side, seat against body - c 2.8
c) seat on side 3.7
d) seat on side - c 3.5
For 7c and 7d, the seat may not touch the body. Unless otherwise noted, the seat
is not allowed to touch the body in any seat out skills, though “seat out” is
not adequately defined.
Please ask more questions as you come up with them, but be sure to read first to
see if you find the answers. Also please tell us where you maybe found an
answer, but it should have been easier to find!
Stay on top, John Foss Chairman, IUF Rules Committee www.unicycling.com
