So I searched a bit and found a German thread from 2006, but not much else…
So I’m learning standup wheel walk and looking for tips and/or hope to exchange experiences: To clarify, stand up wheel walk or stand walk is a freestyle trick standing on the unicycle with one foot on the frame and using the other foot to alternately push/brake the tire to propel yourself forward in a controlled way. It’s like 1ft wheel walk in that you push and then brake to control balance. At first it seems impossible but thus far seems to be progressing faster than wheel walk, which took forever.
From a wall I can usually do 9+ kicks and often around 20, a few times even more. I’ve learned that keeping the unicycle and body quite upright is important. And learning the control processes much like normal wheelwalk/1ft (meaning takes time).
I’m trying to learn transitions into and out of.
Note: my ww and 1ft ww and return-to-pedals are all quite solid but I can’t really do kush-kush (only on the wall) and I’m learning backwards wheel walk. Thus, I also can’t do stand kush.
My step up mount from the floor is getting decent and usually on say 1 of 3 tries I can then do 5+ pushes. But I would rather transition from riding.
Transitioning into there are many options.
pedaling to step up I can do sometimes, but only maybe 1 in 10 tries
1ft ww up I have done, but usually I lean back too far. Not sure why.
I would like to learn to jump from pedals but it is quite intimidating.
Although I can do jump mount to stand hopping quite well (with one hand on the seat), I have never tried jump mount to stand walk. Mainly I’m not sure if I should grab the seat or go straight up without?
To get out, I have 2 options that I can do if I have a helping hand from a partner but yet not alone:
- as the pedals comes around the top, simultaneously move the foot on the frame down to the pedal and lower the body to the seat and pedal. I think this is just a matter of further practice. But tips welcome.
I have also tried going from stand walk to 90 hop on tire (then I can do 90 down to pedals).
So question on the transition out: Is it better to completely come to a stop and then step down or switch to hop on tire? Or is it better to do it in a flowing manner?
