Re: Squeaky Semcycle cranks
Matthew,
I think from your description that you have actually had loose cranks and they
have worn the crank/hub. They have what is called a Morse taper on them and this
should be identical, it is about 1 degree.
As a general rule you should tighten your cranks as soon as you hear them
creak. This is a sign that they are moving and any movement in this area will
create wear.
As you have realised kick up mounts do put consider and this is probably the
reason for the loosening.
I would take your cranks off, but mark where you had them on. Then inspect the
cranks and the hubs. With luck it is your cranks that have worn, the Sem hub is
one of the better ones about so this hopefully will be the case. If there is no
sign of wear… clean up the surfaces up, oil with a very light oil or kerosene,
then put the cranks back on 90 degrees off from where they were previously. Use
a hammer and a block to put the cranks on tight. If there is wear on the cranks,
don’t put them back on, buy new ones, it is worth it as they will damage the hub
in the end! You can get replacement cranks relatively cheaply from John Drummond
in the USA at www.Unicycle.Source.Com If it is your hub and cranks that have
worn… you really need to replace both… or just pop down to your local welder
and weld them up. You have nothing to loose because if you put new cranks on a
worn hub it will ruin them and visa versa.
I hope this has been helpful.
Roger
The UK's Unicycle Source <a href="http://www.unicycle.uk.com/">http://www.unicycle.uk.com/</a>
----- Original Message ----- From: “Matthew Macauley” <mmacauley@nospam.hmc.edu>
To: <unicycling@winternet.com> Sent: Monday, July 03, 2000 5:50 AM Subject:
> Hey all,
> I got a new Semcycle (not the XL) last November which I’ve already ridden a
> lot on (several hundred miles). Recently, the place where the crank is joined
> to the axel has been squeaking quite loudly (both cranks). Has anyone else
> notice this with Sems? I done a fair amount of kick-up mounts and other
> abusive tricks, so I’d imagine that puts extra stress on that part of the uni,
> but it still should hold up better than that.
> I’ve tried oiling it, and this hasn’t worked. But the problem seems to be that
> the axel itself has been over time been worn down and “shaved down,” so the
> end of it is slightly smaller in diameter than the base. So I tried hammering
> the crank further into the axel. This worked for a few weeks or so, but the
> squeaking is back. Maybe it just came loose, or maybe the axel has worn down
> further.
> Is this problem fairly common? I’m a little disappointed in the quality of
> this uni (though it was much better than my old Zephyrs!). I’m sure many of
> you hotshot riders put a lot more abuse into your Sems than I
> do.
Is hammering the crank into the axel the right solution?
> Thanks in advance,
> Matt Macauley http://www.tou.com/host/matt
