I had a metaphysical concern this week end : how do you mount a splined
crank arm on a splined hub ? I mean do you need a special tool because of
the splined grooves ?
Oli-
opaugamATaptilonDOTcom !
Oli-
You can start the cranks onto the axle by hand, making sure the splines
line up. Then pound them on the rest of the way with a rubber mallet.
Chris
> of the splined grooves ?
> Oli-
Or you can cinch them down neatly with the install/remove tool included
with the Profile hub set from unicycle.com. It works really well.
Blessings!
Arthur Doerksen
“Chris Reeder” <reed8990@uidaho.edu> wrote in message
news:3B4A1610.234E0F64@uidaho.edu…
> Chris
> > splined crank arm on a splined hub ? I mean do you need a special tool
> > because of the splined grooves ?
> > Oli-
Did you say INCLUDED? Or sold separately?
Chris
> Blessings!
> Arthur Doerksen
> > splines line up. Then pound them on the rest of the way with a rubber
> > mallet.
> > Chris
> > > tool because of the splined grooves ?
> > > Oli-
