Just some tips if you want to teach people how to ride a uni:
THIS IS JUST MY EXPERIENCE FROM TEACHING PEOPLE
If you have other advice/tips on teaching someone, put it in this thread.
(or if you are trying to learn one yourself, but if you are learning how to ride one, this is for someone who has another person to help them)
I hope this helps us expand our population lol
GEAR- Always MAKE them wear a HELMET! (I donât care if they donât want to, they are going to. and if they refuse - which I donât think they will but if they do, Iâm not the one going to teach them how to, they can find another person to teach them or learn themselves) Wrist supports, knee (or knee/shin guards if you have them), elbow pads, and if you want ankle braces- they should be fine without those since they arenât doing crazy tricks.
UNICYCLE SIZE- Start with your smallest unicycle- usually a 20 inch is good. Also depending on their age as well, if they are 12 or under I recommend a 16 inch or a 12 inch (if they are a like 6 and under)
MOUNTING- start out with them against a wall and you on the other side of them. I know having support on both sides isnât the best but when first starting out I recommend that. I DEFINITLY RECCOMMEND keeping your foot in front of the tire when they first mount so the pedal doesnât slip. If youâre holding them itâs not to much of a problem because you can just catch them but once they are doing it without you holding them and using just the wall, put your foot in front of the tire until they are able to mount safely and balanced.
AFTER THE MOUNT - once they get comfortable and are able to mount, have them sit there for a little bit (while holding them or having them against a wall) Let them get the feeling of just sitting on the seat.
DISMOUNT- I highly recommend once they learn to mount not to just go on to pedaling. They should know how to dismount safely, and once they start riding on, even if they lose their balance, they can try to save themselves by dismounting the right way (or as well as they can) but same thing with mounting, I put my foot in front of the tire to start out until they can do it balanced.
RIDING ON - have them use a wall to start with, have them have both hands on the wall/fence or whatever youâre using. Once they get comfortable with that, then have them use one hand on the wall and one holding the seat. Make sure that they switch their hands that are holding the seat, so they arenât always relying on one side for balance.
NO WALL - Once they feel comfortable enough with the wall and you notice they arenât leaning as much or relying on the wall as much have them ride off but make sure to hold them at first and then stay close by after they are doing better. if possible, try riding somewhere near grass or have them ride towards grass in case they fall.
Although Iâve never tried this before but using a walker (granny walker) could possibly help someone balance, but you donât want them using it to much because it can start habits of leaning forward and then theyâll have trouble balancing without it. starting out with it to get use to the feeling. now Idk if this would actually work but try it out first before you make someone else do it lol.
- OTHER TIPS - Take it slow! I know your friend/person ur teaching is going To want to just go fast and rush the process because they are excited! but donât rush it! It is very different, and you have to be careful! Alot of times people wnat to learn and then they get hurt and then never want to ride/ learn again. i also recommend that the person doesnât start peddling the day they learn to mount the unicycle. Wait a day and then the next time or day have them start learning to pedal. Or wait til the person can comfortably mount the uni and then start learning to pedal.
My sister learned how to ride one and taught me, she taught me how to get on and then said to just go for it. I would go for it and fall and she was like âjust keep peddlingâ girl how am I supposed to keep peddling if Iâm falling? But any who I learned eventually but not the best advice for someone starting out. I originally used my garbage cans to start riding, I would lean on them and rude around them until I got comfortable riding on.
