slackrope
Hello Nic,
You might want to start here:
http://www.juggling.org/help/circus-arts/slackrope.html
-=+=- Phil Bartel -=+=-
COMPUTERVILLE Windows 95 & Internet Support
Voice (619) 477-4794 FAX (619) 477-4695 E-Mail felipe@computerville.com ICQ
#7327095 740 Tenth St., Imperial Beach, CA 91932-2216
>-----Original Message----- From: unicycle@tartarus.uwa.edu.au
>[mailto:unicycle@tartarus.uwa.edu.au] Sent: Tuesday, June 29, 1999 09:50 To:
>Felipe Subject: slackrope
>Received: from icicle.winternet.com [198.174.169.13] by mail.tnl-online.com
>with smtp id AIDBBNAM ; Tue, 29 Jun 1999 08:49:28 -0800 Received: by
>icicle.winternet.com (8.9.3/8.9.3) id KAA07859 for unicycling-outgoing; Tue, 29
>Jun 1999 10:47:08 -0500 (CDT) SMTP “HELO” (localhost) No greeting given We have
>no validated sender SMTP “MAIL From” = owner-unicycling SMTP “RCPT To” =
>unicycling-outgoing X-Authentication-Warning: icicle.winternet.com: server set
>sender to owner-unicycling using -f Received: from elysium.uwa.edu.au
>(root@elysium.uwa.edu.au
>[130.95.128.2]) by icicle.winternet.com (8.9.3/8.9.3) with ESMTP id KAA07566
> for <unicycling@winternet.com>; Tue, 29 Jun 1999
>10:46:23 -0500 (CDT) SMTP “HELO” (ESMTP) greeting from elysium.uwa.edu.au But
> really from :: root@elysium.uwa.edu.au [130.95.128.2] SMTP “MAIL From”
> = unicycle@tartarus.uwa.edu.au SMTP “RCPT To” =
> <unicycling@winternet.com> Received: from tartarus.uwa.edu.au
> (unicycle@tartarus.uwa.edu.au [130.95.128.3]) by elysium.uwa.edu.au
> (8.8.7/8.8.0) with ESMTP id XAA16190 for <unicycling@winternet.com>; Tue,
> 29 Jun 1999 23:46:18 +0800 (WST) Received: from localhost
> (unicycle@localhost) by tartarus.uwa.edu.au (8.8.8/8.8.0) with SMTP id
> XAA03379 for <unicycling@winternet.com>; Tue, 29 Jun 1999 23:46:17 +0800
> Date: Tue, 29 Jun 1999 23:46:17 +0800 (WST) From: Nicholas Seow Chiang
> Price <unicycle@tartarus.uwa.edu.au> To: unicycling@winternet.com
> Subject: slackrope Message-ID:
> <Pine.LNX.3.96.990629234055.1939B-100000@tartarus.uwa.edu.au> Sender:
> owner-unicycling@winternet.com Precedence: bulk Reply-To: Nicholas Seow
> Chiang Price <unicycle@tartarus.uwa.edu.au>
>OK, I know it’s not about unicycling, but given the recent thread about flying
>/ balancing / unicycling, it’s reasonably relevant.
>I’ve just restarted learning how to stand on a slackrope. At present I can stay
>on for over a minute and can take a few steps forwards and juggle a little bit,
>but my legs are really really tense, and get quite sore. Does anybody have any
>experience / advice on slackrope, or know who I should ask?
>As for the awareness of balance issue. On a slackrope, the concept of how you
>stay upright is just as crazy as on a unicycle. Basically very small body
>movements and arm movements keep your centre of balance over the rope, which is
>only a centimetre wide. I doubt I could do i blindfolded, because I am
>completely dependent on visual cues for focussing my mind and body. I think
>that your brain responds a lot faster to visual rather than inner-ear balance
>cues, and since there are direct reflex connections in your brainstem between
>your visual cortex and motor centres, it’s (almost) evident that visual cues
>are very important for maintaining balance.
>As with all balance things though, it’s best to let your body and brain
>subconsciously work it all out. Thinking about it just makes you fall over.
>cya nic
OK, I know it’s not about unicycling, but given the recent thread about flying /
completely dependent on visual cues for focussing my mind and body. I think that
your brain responds a lot faster to visual rather than inner-ear balance cues,
and since there are direct reflex connections in your brainstem between your
visual cortex and motor centres, it’s (almost) evident that visual cues are very
cya nic
