How the heck do you start learning this trick!?! I’ve tried a little on my own, but thats not going anywhere. Do you need someone to help you stay up or just keep on trying yourself until you get the feel. And is there an advantage to using one or two feet?
Start from standing on the ground, not from the pedals, and it might help to be walking forward a little so you have momentum when you first start.
You want to use both feet at first, but the forward leading foot takes most of the weight/most of the pushing.
If that helps you learn it, maybe I should try…
