Seeking advice on a G29 build (titanium frame?)
The build has begun!
Is the cat part of the build? If you put it inside the wheel, will it make it roll like a hamster? :upside_down_face:
No, she’s only inquiring whether I’ve diverted her fish fund.
It’s my first time lacing a rim, it’s fun and not particularly hard with the help of the great videos made by ParkTools; it only requires a tad of patience. The LBS guys praised me for my work, proud of it!
Putting on the tire was the hardest part, as discussed here. Fortunately I found the right guys to help me install it, just before I was going to give up.
So my Ultimate Commuter build is now done! Thanks to everyone who gave me help in this process!
Pics will come soon!
Some quick snapshots:
That looks very nice. Very clean. Very envious I am.
That is a thing of beauty! Great choices all round :face_savoring_food:
You may have mentioned it elsewhere, but what rim is that?
It’s a Nextie, with an inner width of 35mm, weighs 450g.
Here is the full specs (click on each of them to expand details):
[details=“Frame: Custom “Saturn” Titanium Frame, Seat Post and Clamp”]
  • 31" frame (400mm fork length)
  • Dual disc brake tabs and cable holders
  • Schlumpf hub (2015) compatible bearing house
  • Weight: 793g
    [/details]
Rim: Nextie NXT29XM41
  • Toray T800+T700
  • Spoke Hole Angle: ± 6°
  • BSD: 622mm
  • ERD: 581mm
  • Outer Width: 41.4mm
  • Inner Width: 35mm
  • Rim Thickness: 30mm
  • Recommended Tire Width: 2.2-3.0"
  • Max Spoke Tension: 80~130kgf
  • Weight Limit: 120kg
  • Max Tire Pressure: 25-60psi
  • Weight: 455g
Hub: KH Schlumpf Hub 2015
  • Flange Width: 66.7mm
  • Flange Diameter: 91.5mm
  • Spoke Hole Diameter: 2.9mm
  • Weight: 1420g
Tire: Surly ExtraTerrestrial 29 Slate-wall
  • Size: 29x2.5 (64-622)
  • Bead: folding
  • TPI: 60
  • Max. PSI: 60
  • Weight: 1070g
Tube: RideNow 29'' TPU
  • Valve: Presta 45mm
  • Weight: 56g
Spokes: Sapim Race, with Sapim aluminum self-locking nipples
  • 270mm
  • 2.0-1.8-2.0, 14G
  • Weight: (6.25g + 0.34g) x 36 = ~238g total
  • Amount: 36
Brake: Shimano BR-M446/447
  • Rotor: 180mm
  • Weight: 302g
    ** Inherited from my KH26 **
Saddle: KH Fusion Freeride
  • Weight: 830g
Cranks: KH Spirit Double Hole 117/137mm
  • External Disc Brake (EDB) compatible
  • Weight: 402 g
Pedals: Unbranded flat pedal
with sandpaper surface
