I am the one who did not screw the “set screw” with the 2mm Allen key, to secure the shift button setup in place and who lost as a result one shift button on the road.
Florian actually shipped to my attention 2 spare shift buttons, which I received last week.
Interestingly enough, the payment for it is differed to September, as per Florian’s request, because it looks like he not even has got the bandwidth to process this type of “side” actions those days. I’m really glad he trusts me!
BTW, yes, I ordered 2 buttons (both silver) - because I wanted to use this opportunity to “silverize” the gold button, and by doing so make my Guni a little bit less “fancy” and “attractive”, for the potential thieves out there. And anyway I am not myself running after the gold finish at all…
I therefore completed the setup of my 26" Guni yesterday, and went for my first off-road Guni ride!
Well, in fact, my plan was to remove the slick tyre which I had used for the l’Alpe d’Huez climb the other day, and put instead the off-road tyre (because I’m primarily an off-road rider). But guess what? I just couldn’t find my torque wrench in my garage! At first, I went a bit crazy, realizing how unorganized I can be
but did not want to cancel my ride for such a silly reason, so I went for my ride with the slick tyre - hoping that the dry ground and the relatively friendly tracks I had planned to ride would accommodate from a slick tyre.
Hey… it was my first “gearing while riding” experience ever on a unicycle!
Yes indeed, because I had done so far only one ride with both shift buttons on, and didn’t plan to practice the on-the-fly shifting that day. Since then, I was living with one single shift button, so had to forget about the great “gearing while riding” idea!
My very first (<10) attempts to shift on the fly were actually failures.
Either I could not change gear, or I changed it but could not stay on the unicycle after the gear changed. But then, probably because I was physically “hot” and perhaps less “intimidated” by the concept (more confident), I successfully did my first “low to high” on-the-fly shifting, and then the other way around (back to high gear), with the same success. What a satisfaction it was!
Strangely enough though, during the 2nd half of my ride, I just got less successful while trying to shift on the fly. Not that I could not adapt to the new gear and fell off - but rather that it became harder for me (my feet) to trigger the change of gears. Note that I am using pretty grippy pedals, and am wearing the Five-Ten Karvers shoes - which might partly (but partly only) explain why the shifting wasn’t that easy for me anyway.
I used 150mm cranks so far, and will give a chance to the 137’s, perhaps even 125’s, in the future rides, in order to learn where my preference is after all.
I did not have any hardware problems - excepted that my right crank would get loose every few kilometers. I will definitely plan to loctite the crank bolts once I will have “settle down” to the right pair of cranks. Well… “right pair of cranks” does not mean much, I’m afraid, and I’m sure I will regret a little the fact I’ll loose the flexibility of changing cranks depending on my rides.
In summary, it was a really fun and fruitful ride.
I feel like being one the first step of high stairs though, and will have to practice and practice and practice in order to (90%?) successfully shift on the fly and also shift in a safer way. I am really eager to (find back my torque wrench and) put the offroad tyre on!!!
In 4 weeks from now, I will fly to Tunisia with my Guni, and plan for a few rides which I think will be very enjoyable! I will just have to be careful with the heat of course, and avoid starting my rides too early (perhaps not before 5:00PM, like 5:00PM-to-9:00PM or so).
I’ll also post pictures of my Guni as soon as the off-road tyre will be mounted.
Cheers… MadC.
