Riding Down Stairs
I have ridden down VERY WIDE stairs and can do that fine now, it’s almost like going off many continuous little drops. But now I want to be able to ride straight down a normal set, but everytime I try the uni (20" trials) just shoots out from under me after a couple of stairs or I fall back! I cannot find any posts about riding straight down a set, can somebody please give me some pointers?
Many thanks!
put a lot of weight on the pedals by pulling up on the handel that way your feet wont slip of from the viabration. it just takes practice start on a 3 stair and work your way up to the occasional 30 stair with no run off
^what he said & you’re probably too scared. it’s all about commitment
I sort of had the same problem. I think it helps just to hold your seat. I dont really know why, but it does. Don’t think about it too much. Just do it. And standing up helps as well when learning. Make sense?
+1
just go for it and don’t be scared and remember to wear your helmet
Helmets are for grandma. Who needs their noggin?
Yes it does, it helps a lot standing up i’ve found!
Steeper steps are just a steeper hill with regular bumps.
Get your weight off your seat and just ride down. Going a bit faster is probably easier than going slower, so just go for it.
Theres a dh race down stairs in Stuttgart this year. The website is featuring some tipps (you may have to click the english flag up in the left corner):
http://stairandstyle.appspot.com/stairs/stairhowto
Pull up on the handle really hard. Also just commit, if you loose your balance while riding you can just jump off the uni.:smiley:
like everyone else has said, you just need to commit and if you loose balance jump forwards away from the uni. :slight_smile:
Just don’t jump too far forward :smiley: especially if the stairs are long and steep :astonished:
And no helmets are for retards that are too worried about thier self image and peer pressure instead of living a life as a mentally impaired person who can no longer be self sufficient or independant.. Wow that would be SO much cooler then a helmet..
i think he was jokin, maybe not..but
i’m a huge advocate of wearing helmets myself, and i’ve never hit my head..tho ive had many falls on my tailbone, and if a curb or stair was behind me on any of those falls i’d be lucky cause i always wear my helmet.
there is one actual person on the forum who says using a helmet for unicycling is useless though. ridiculous!
i can’t ride up to my maximum potential if i dont have my helmet on.
Hahahaha that would be Rowan… I personally don’t wear one much because I can’t find one that I like and I ride mostly flat, but I definitly can’t see how it would be bad to wear one. :thinking:
