Removing nubs from peddles
I grew up riding a Schwinn with smooth rubber peddles. I usually wore shoes but rode barefoot often.
I can’t stand the nubs on the stock Nimbus mountain Uni. I mount the Uni and my left is foot is too crooked every time. Correcting it takes up to a few rotations of the tire. Not to mention it takes longer to get a decent right foot plant as well.
Has anyone removed the nubs from their stock peddles?
I don’t know if the design would make for too slippery of a surface as their isn’t much there.
The Schwinn’s had 2 rubber runners around 3/4” running the length of the peddle. I don’t recall ever having a problem with my feet coming off them. I’m not one to ride in bad weather or up steep hills, I’m 65 and mild grades uphill are no fun. I live in Vermont and have an E-bike designed for Vermont. I’m strictly a flat-lander on the Uni that is aware of his age. I won’t be leaping from porches or boulders. I broke my pinky finger 2 years ago when a Uni mount went horribly wrong as I tried to protect myself hitting the ground. I question the sanity of riding at all but I like it.
I just need what I deem normal peddles which seem to be a bit of a unicorn these days.
Thoughts?
Go to bikestore, buy what you deem “normal pedals”, install, done?! At least where I am there always are some of those basic flat pedals with rubber available.
You can remove the pins from plastic pedals with a file or woodworking rasp. Tends to be okay in the dry but very slippery with any moisture.
Yeah, thanks for your time, I live in rural Vermont and the bikestores are few and far between. Plus, they don’t stock much. Its not a good State for buying much of anything to be frank.
I found some Sunlite Barefoot Cruiser MX Pedals on Amazon, they seem alright.
Hi, Terry…I ground one side of the pedals nubs so if I felt I would need them later, I will have them (doubtful). I have two total knee replacements , so there is very little if any lateral rotation. Planting my foot a little off causes heels to hit, tension in my knees, a lot of problems.
I found that keeping the nubs and wearing a loose fitting shoe provides excellent grip while allowing to foot to move inside the shoe.
