Text item:
Roger Davies wrote:
>You might need a whole new uni I am afraid. Ok here goes…Design is, 25mm od
>CrMo tube with flanges welded on: This is the core and it will be bomb proof it
>is well tested by the BMX guys.
I’m planning on having a whole new uni made, so I’m open to new ideas. Would you
be able to supply me with exact specifications of your bearing holder so
whatever I have can be attached to it?
>OK I admit it this is the best but requires a major re-design to the unicycle.
>Plan B is to use 20mm od Tubing and 6004 bearings. With only a slight mod my
>uni’s can be used as the OD of the bearing is 42mm. It would be heavier though
>and probably not as durable, but conciderably better than a normal uni.
If I understand you, unless someone is using one of your frames, new bearing
holders would have to be made in either case. If that’s true, I prefer the first
larger tubing.
>Completion of project… I asked the same, I will ask again tomorrow but on
>first try he thought 2 months to sort the design out.
Any idea on cost? I want to build at least two unicycles for myself, and if it
works nice and is not too expensive, others may want them as well. I’m thinking
of adapting a suspension fork, but haven’t decided that yet. Have you done any
experimenting with suspension seatposts?
As long as I’m speculating, what’s the estimated cost of this new hub/bearing
system along with one of your carbon frames?
Thanks, John Foss
Text item: External Message Header
The following mail header is for administrative use and may be ignored unless
there are problems.
IF THERE ARE PROBLEMS SAVE THESE HEADERS.
Reply-To: Roger Davies <Roger.Davies@octacon.co.uk> Precedence: bulk Sender:
owner-unicycling@winternet.com Content-Transfer-Encoding: 7bit Content-Type:
text/plain; charset=us-ascii References: <Mon, 16 Mar 98 13:24:41
PST_4@ccm.fm.intel.com> X-Priority: 3 (Normal) Subject: Re: of seatposts and
hubs To: JohnX Foss <JohnX_Foss@ccm.fm.intel.com>, “unicycling@winternet.com”
<unicycling@winternet.com> MIME-Version: 1.0 X-Mailer: Mozilla 4.0 [en] (Win95;
I) From: Roger Davies <Roger.Davies@octacon.co.uk> Date: Thu, 19 Mar 1998
22:12:43 +0000 Message-ID: <3511985A.24F069A8@Octacon.co.uk> Received: from 486
(p03-27.onyx.net [194.176.64.219]) by goole.octacon.co.uk (8.
6.9/8.6.9) with ESMTP id WAA20392; Thu, 19 Mar 1998 22:57:53 GMT Received: from
goole.octacon.co.uk(193.118.80.1) by icicle.winternet.com via sma
p (V2.) id xma005486; Thu, 19 Mar 98 17:00:49 -0600 Received: (from
adm@localhost) by icicle.winternet.com (8.8.8/8.8.8) id RAA05739 for
<unicycling@winternet.com>; Thu, 19 Mar 1998 17:01:55 -0600 (CST)
X-Authentication-Warning: icicle.winternet.com: server set sender to
owner-unicy cling using -f Received: (from server@localhost) by
icicle.winternet.com (8.8.8/8.8.8) id RAA05886 for unicycling-outgoing;
Thu, 19 Mar 1998 17:02:39 -0600 (CST) Received: from icicle.winternet.com
(icicle.winternet.com [198.174.169.13]) by thalia.fm.intel.com
(8.8.6/8.8.5) with ESMTP id PAA08141 for <JohnX_Foss@ccm.fm.intel.com>;
Thu, 19 Mar 1998 15:17:38 -0800 (PST) Received: from thalia.fm.intel.com
(thalia.fm.intel.com [132.233.247.11]) by fmm ail.fm.intel.com
(8.8.5/8.7.3) with ESMTP id PAA23651 for <JohnX_Foss@ccm.fm.int el.com>;
Thu, 19 Mar 1998 15:13:10 -0800 (PST) Return-Path:
unicycling-owner@icicle.winternet.com
