Quick question about frames
Question! If I wanted to get a new frame for my torker DX what are my options? Could I stick a nimbus trials frame on it?
could I stick either of these to replace my torker frame?
http://www.unicycle.com/shopping/shopexd.asp?id=1076
http://www.unicycle.com/shopping/shopexd.asp?id=1073
The bearings on a Torker DX are 40mm, and the holders on the Nimbus frame are 42mm. You might be able to purchase the bearing sleeves (available on the UDC website) to increase the diameter, but I’m not sure if the spacing between the bearings is the standard 100mm. Hopefully other people here will have more knowledge on this subject.
Yes, it works. I have a nimbus trials frame on my unicycle. The other guy is right about the bearings though. you need 20X42X12 or something to that effect. Just make sure it has the 42 thats all that matters :stuck_out_tongue:
You can use a cut pop can, it works, I’ve done it. Not hard to do at all.
Ok, then with that being said… What would be a good frame to stick on my torker? I use it for pretty grueling street riding and am looking for something light. Any suggestions?
the nimbus trials frame.
