Re: Q’s about idling
[QUOTE]
Originally posted by Sofa
[B]Hi, I have read several things about idling. The 9 - 3 ‘half rotations’ and such, but my question is this:
Do you constantly rotate your pedals back and forth, or do you only do it when you’re about to loose balance, and thaqt tire movement will save you? Or is it personal pref? >>
>>>>>> If I’ve understood correctly, you’re asking, “Do I have to keep going back and forth to idle, or can I sit still and only go back and forth when I need to?”
Just siting still would probably be called a ‘static rest’ or some similar name. It’s difficult to do for more than a second or two as nothing ‘dynamic’ is happening. The uni just sits there until it gradually tips in one direction or another. The more perfect the static stand, the harder it is to predict which way it will eventually fall. Once it starts to fall sideways, there is little you can do to stop it, due to Newton’s laws, but if it falls forwards or backwards, you can usually catch it with a half idle.
On the other hand, when you are idling, you are in a position of dynamic stability. You are always ‘falling’ one way or the other, so it is very clear at any moment which way you have to counteract the fall. Also, if you start to fall sideways, the wheel automatically goes into a slight curve which tends to throw the centre of gravity back over the wheel. (When idling, the wheel follows a curved path - usually an s, but sometimes a c. (If it follows a treble clef, then you’ve really got something.)
So, the answer to your question, the long way round, is that they are two separate skills, but if you want to idle for longer than a second or two, or if you are in a real riding situation, a constant back and forth of the wheel, with constant reflex correction of balance is the way to go.
A simpler answer is: it’s much much easier to idle with a bit of forward and backward movement, so do it that way. :0)
