It must be because Iām not technical at all, but why develop a new wheel? Canāt you just replace the current 32" hub with a geared hub? Maybe shorten the spokes if needed.
Iām not sure I follow. The project here is to build a custom designed 32ā unicycle.
Buying a bespoke carbon rim ready made for the planned hub is definitely easier and preferable to buying a stock unicycle and then rebuilding it with a geared hub.
Iām pretty clear eyed on these projects as being theyāre own pleasure āsportā that fits in nicely with winter
Damn, that rim looks like itās going to be SLICK! I think you win the āMost drool-worthy unicycle buildā award again!
@Setonix - there comes a point where you want to use so many custom parts that thereās no point buying a ādonorā unicycle. Mindbalanceās projects are miles past thatā¦
which is clear from the Huni-Rex where the original company went bankrupt. Lucky me they did produce 1000 items. With a bit of luck it will arrive by the end of the week. Then by the time this G32 is ready, I will have had so much experience on the Huni, that I will easily out-run the 32
