How different is aluminum welding in TIG from MIG?
I’ve never tried a spool gun because my teacher says it’s cheating but he does accept the use of it for tacking things that dont want to cooperate. So I can’t answer that
Technically an EUC but I thought someone might be interested, im going to buy spokes when I get paid on Thursday, these are either too long or too short
Almost done, I did a balance test to see if it would explode or not, it did not so now I just have to shorten the frame because its a bit too long then do a final assembly and ride test
is the big black thing on top your balance-tester or something? It isn’t quite clear what you want to achieve with the EUC wheel in the middle. Do you want to make a big wheel EUC?
I extended the EUC frame so i could put a 36" wheel on it, the wheel in the middle is actually the hub and the black thing on top is the original EUC
And why do you have so many pill boxes on the floor next to the wheel? Is it such a crazy idea, that you need the pills? :smiley:
So all that is missing are the flaps, which you put at hub level? My Kingsong has them below which might make it easier on the self balancing computer. Also how will you guide cable so it doesnt get damaged when (not if) you tumble off. Looking forward to your test drive video.
The V11 is notorious for being hard to disassemble and having way too many bolts, the pill bottles are my way of storing them so they dont get too mixed up.
The pedals are a couple inches below the axle and will go lower when the suspension is loaded.
Im going to wrap the wires in electric tape then shove them in some plastic wiring tubing and maybe hold it with zipties or hose clamps
