RE: Pedals
> >"You idiot! Why did you buy that cheap “T"cycle in the first place?”
As a guy who reads the newsgroup in the form of email, it’s clear that I’m not
seeing all the messages. I get lots of replies to original messages that never
came through, like the above.
> “T” is for Titanium, right?
Someday. Start saving up!
> The great thing I like about “T” cycles is they’re upgradable. You can get a
> $100 pile of fun, and when you get bored, you start upgrading parts.
“T” cycles are great for light riding, or for lightweight riders. But if your
riding involves lots of tricks or trails, or if you simply weigh more than the
average kid, you might want to aim higher. The core parts of a bad unicycle
cannot be replaced without essentially starting over. If it has those lollipop
bearings with the bolts on the sides, for instance, the best upgrade is a new
unicycle with a different frame.
> As for pedals, I’ve seen some plastic pedals wear out, but I’ve also seen some
> really cheezy looking metal pedals that probably wouldn’t last any longer.
> I’ve even had an $18 pair of “trap” style pedals that the rivets came loose
> and started creaking.
That’s right. There are plastic pedals that can be very good (even cheap ones),
and metal pedals that will fall apart. Most unicycle pedals are at least “okay”,
but again if you ride a lot, or do lots of learning that involves lots of drops,
they’re going to wear out.
> needed, but I don’t think you’ll ever break the pedal. (Someone may speak
> otherwise here.) There are no rivets to come loose, either.
Most pedals on unicycles don’t bend, and they usually don’t fail from riding.
They get their most damage from drops. That’s why lots of metal trap pedals get
bent and distorted on the ends. This usually doesn’t affect their usefulness
much. Also I have indoor pedals with rubber/plastic ends. Eventually the plastic
wears away and the ends start to come off. This is normal use and service; time
for a new pair.
[Does anyone know where I can get the old-style Semcycle pedals? I don’t think
they have them any more. These were the ones with the squared-off ends. My very
favorite freestyle pedal.
On my MUni, I have a pair of inexpensive rattraps (forget the brand, $20 or $30)
that have worked well for about four years. I want to replace them with a pair
of WAM B1’s though, like I have on my other MUni…
Stay on top, John Foss, the Uni-Cyclone http://www.unicycling.com
“It’s never too early to be Friday” - John Foss
