In response to Semach’s "wow, magnesium pedals thread, I thought some of you would like to see my research about pedal weights. Pete is not allowed to read this.
Please note :
Weights are for a pair of pedals in grams.
Different site’s listed weights for the same pedals were close. Say about 10 g + -
sb and lb means sealed bearing and loose bearing
I’m sorry I left out your favorite pedal :o
grams
DK Iron sb-lb 879 Ahnold’s favorite
Primo tenderizer alum lb 794
Odyssey JC alum sb-lb 730 Do you still love em ? :confused
Snafu alum lb 694
Snafu alum sb 640
Primo pro tenderizer mag sb 620 Mag can be heavy too !
Hoffman sole mate alum lb 612
Odyssey twisted alum 607
Odyssey JC Mag sb 578
Atomlab trailking alum bushing 540 unique bearing design
DMR V12 alum sb-lb 520
Eastern mag lb 510
Primo mag sb 470
DMR V12 mag sb 434 60 $ A E Bike
Odyssey twisted plastic lb 411 12 $:)
Welgo mag sb 375 pedal falls off if bearing fails
Welgo MG1 mag sb 368 same problem as above ?
DMR V12 mag sb with Ti axles 354 100$/pr axles sold separately
Dimension nylon lb 330 8 $
chromoly axle
And there you have it. Any comments ?
All my neatness in columns didn’t come out right
Oh well, it doesn’t look as clean as I did it, but it’s readable I hope.
If you could edit it and align the weights and prices that would be cool, easier to compare that way. Nice list though, I still stand by my odyssey twisted plastics and this reinforces that.
Those dmr mags look good, but at more than double the price of the azonic mags, and about the sane weight, I’ll stick with the azonics. (WHich you didn’t list
) They are about $29 vs $60+ for the DMR.
I have some odyssey twisted plastics too, brian, and I love them as well…but only on my KH 20.
As soon as they get wet…and sometimes when they don’t…I can’t keep my feet on them, they just slip all around them. This is a problem on a short-crank, big-wheel uni, because you need to put a lot of torque and power into the pedals, and when your feet slip off, that’s bad.
I created it with neat columns
But when I hit post, it came out all smooshed together.
I think this has a lot to do with the shoe you are wearing as well. While they do get a little slippery when wet I don’t find them any worse than most other pedals - namely the Jim Cs which I find pretty slippery when wet. I’d say they perform relatively well when wet in comparison.
Pedal protectors
I forgot to add pedal protectors. And after I took the time to weigh a set on my expensive digital scale that is accurate to .o1 gram (don’t ask). Pedal protectors weigh 70 grams/pair.
HTML strips away extra spaces. The forum has an option to post code tags, html tags or php tags around the text to make it monospaced and keep the formatting (spaces and tabs).
Please note :
1. Weights are for a pair of pedals in grams.
2. Different site's listed weights for the same pedals were close.
Say about 10 g+-
3. sb and lb means sealed bearing and loose bearing
4. I'm sorry I left out your favorite pedal
grams
DK Iron sb-lb 879 Ahnold's favorite
Snafu alum lb 694
Snafu alum sb 640
Eastern mag lb 510
Primo mag sb 470
Dimension nylon lb 330 8 $ chromoly axle
Surprise ! John has the answer !
Thank you Mr. Childs.
OK, so html was screwy, what option should I have checked ?
Write the post in a text editor that uses a fixed width (monospace) font.
Then copy the text into the forum editor and put the HTML tags around it (you can use the “<>” button in the forum message editor to put the proper tags around the text).
One more to add to the weight-weenie arsenal - I’ve recently put lightweight rat-trap type pedals on my coker. They are smaller and less grippy than pinned platforms, but with my plastic toe-cup things (about 90g for the pair) they are comfy enough for me. They also have about 1cm less q-factor each than normal platforms (making my shoes very close to the cranks, but with slim, figure-hugging shoes (rather than skater shoes) this is fine). They have very smooth, sealed bearings.
To make the toe-cups stick far enough forward to get the ball of my foot on the axle I have put a 1cm block of wood (weight negligible) between them and the pedal.
Available new from an eBay shop (UK) £12.95 + £2.50 shipping.
Weight per pair: 260g (9.17oz). (That makes ~350g with the toe-clips)
Sam
red welly of China ?
Just joking on the name LOL . Those pedals look a lot like these
http://aebike.com/page.cfm?PageID=30&action=details&sku=PD1091
Do you think they are the same thing ? You like them ? and for how long ?
At 270 grams, you are a true weight weenie.Can you get into a Mc Donalds riding that thing ?
They seem to be the same concept, only a different brand. The VP ones have a little tag to help with flipping them over into toe-clips, and allen-bolts rather than screws holding the cage.
I like them so far. They do feel less ‘big and solid’ than platforms (I had standard wellgo platforms before), and they are boring black rather than ‘go-faster red’, but I like them. They are very grippy if I wear the right shoes - snug in to the toeclips and the right part of the tread - it feels just as good a contact as clipless cleated shoes do. It’s a slightly better feeling of snug contact and being able to pull through the whole pedal stroke than using toe-clips on platforms had.
I’ve only had them on for over a week, but done a good few hours on and off-road with them now. As my 36er is currently set for muni with 152mm cranks and softer tyre pressure I can’t really compare with ‘fast efficient spinning’ until I go back to road-mode after the Mountain Mayhem 24hr event.
I think they feel lighter, though it’s hard to say, as they feel different too. But near halving the weight of the pedals (was 660g, now 350g) can’t be a bad thing!
Sam
Hmmm. I have some of those sitting around that I meant to put on the coker, but didn’t get round to what with being away. Maybe I’ll pop them on the Schlumpf and have a go.
Would you trust them for proper muni rides, or do you think toeclips are only for cokers?
Joe
Primos rock!
You left out Sun Ringles. $35, about medium weight. Definitely lighter than the Primos.
I don’t think toeclips are worth bothering with for real muni, as it’s too much faff getting into them if you are doing bumpy stuff, and weight saving isn’t as important.
I don’t usually worry about getting stuck in them, even in UPDs.
I’d just go for pinned platforms except for cokering.
Sam
alright, I know this is an older thread, but I found some LIGHT pedals on fleabay. Wellgo MG-1 with Ti spindles, 298g a pair, $116 usd with $15 shipping to anywhere. linky
dealer much?
yeah, ill have a misdemeanors worth of “pedal protectors” please.
