Boy, I’ve been doing crank grabs all along. I never realized how much harder it is for pedal grabs! Soo much more balancing, and much more of a workout
What is it called if you do a bit of both? I generally land on just the pedal, as it seems you can go that little bit higher that way, but then shuffle the crank onto the object to make jumping the last bit easier.
I’ve tried just using the pedal a few times, it’s terribly wobbly…
Phil
yes, pedal is wobbly at first, but now, i haven’t done a crank grab for ages. Pedal grabs become so easy and controlled… a beautiful thing really:D .
-Ryan
