PAU Power Assisted Unicycling, Hypershell Mountain Exoskeleton
Hi, Its been a couple of months since I bought the Hypershell Mountain Exoskeleton Pro X 1hp and started my PAU power assisted municycling adventures with E-legs.
So thought it was time to do an update. I have made a few improvements, to the harness I added a, mobile phone mole, water bottle hose magnetic clips, water bottle mole, high visibility patches. See piccys below.
The hypershell is more versatile if you a phone conected to the device and have the app running, but its not essential.
The cycling mode is excellent, no real change needed, however an improved version downloaded to my phone and device today, which I cannot wait to try, plus you can fine tune it to your needs if you wish.
Everything is super easy to use, and boy does this thing deliver and perform.
1 hrspwr, thats 10 x fit adult men, plus you. No joke. 30kgs weight off set. When I have used it, I feel less exerted, less out of breath, less tired, less fatigue.
So far I have only gone to Eco pwr lvl 3, but mostly lvl 1 or 2 is more than plenty. Lvl 3 as much as I will ever need, and still 5 power levels increases to go.
I can use it on all 6 unicycles without any change, which makes it really versatile. On the road it is great, off road, mega. It may not look it, but this things got loads of power. Walk, run, sprint, hike, cycle, unicycle it has a mode.
My riding has been more confident, stable, and I have not had a UPD since I bought it. Distance has also incresed. Its taken a little getting used to, but my riding has also improved, and I can tackle obstacles I might have avoided, with more confidence, knowing my legs can deliver. Uphills a breeze :grinning_face:
It works perfectley on any of my 6 unes, I can use it for hiking, going up and down hills or mountains. New modes being added shortly are “Dune”, “Boot Packing” and a couple of others.
So hiking, snow board, skiing, mountain climbing, cycling, unicycling etc
I horse pwr, 40% increase in leg strength, 30kgs weight off set and that my friends makes a huge difference.
Well designed, well made and it delivers on every level. App intergration and use easy. Well impressed.
I dont really have any negative comments, it feels seamless, you dont notice it, power delivery is in tune with your every move, in real time. Your legs just feel stronger, you feel lighter. When you turn it off, you do feel it though, 30kgs heavier all of a sudden, but thats short lived.
If you have bad hips or knees its porbabley not for you, on the higher power settings I have noticed it in my hips n knees, but again short lived. Using the hypershell has not affected, riding without it, I just cannot go as far, or enjoy myself so much.
Battery is quick to charge and lasts well, and you get 2, so range is no a big issue. Unit weight 2kgs mostly in the battery, you dont notice it.
Pictures below of the harness mods I have made. The harness is not needed or required for use, it just means I can carry stuff on the une while riding.
Also insight into the app and the motion engine settings that can be “tweaked” and the various modes, currently available, 4 new ones coming on stream to test soon I believe. Water bottle and hose fits to either une or hypershell for on the move refreshment :grinning_face:
Thank you for the in-depth review!
