Pashley seat post
My Pashley seat is falling apart and I want to replace it with a Viscount,
available from DM unicycles. However this requires a different seat post to the
original and he asked me if the Pashley is 25mm or 1 inch diameter. I do not
have a micrometer and it is difficult to judge with a tape measure! Does anybody
know the answer? My Muni is a current model, only about 4 months old.
Thanks
Jerry Cooper
Re: Pashley seat post
I had a local bike shop weld a used “regular” bike seatpost to my Miyata seat. I
don’t have a micrometer, so I can’t tell you the exact diameter of the
seatpost–but the bikeshop matched the Pashley seatpost. It is extra long so
that it has more surface area to prevent any movement, and works with my long
legs. I recommend it as a low-tech solution.
David Maxfield Bainbridge Island, WA
> the original and he asked me if the Pashley is 25mm or 1 inch diameter. I do
> not have a micrometer and it is difficult to judge with a tape measure! Does
> anybody know the answer? My Muni is a current model, only about 4 months old.
I couldn’t tell you which one, but there are 25.4 milli-meters in an
inch. Hope this helps. Also .4 milli-meters shouldn’t make a whole lot
of difference between the two posts. Am I wrong in saying this??
                                            Chris Cline MUni-Cow
It costs a bit of money, but I had a machinist make me a set of standard rails
that replace the old welded seatpost attachment on my Miyata seat. This way you
can fit any sized bicycle seatpost you want, including seatpost shocks if your
MUni seatpost tube is big enough, and you can also adjust the angle of the seat
to whatever is most comfortable.
-Kris.
post to
I do
Does
months old.
Kris Holm, B.Sc. Geologist, Forestry Group, EBA Engineering Consultants Ltd.
Suite 550, Sun Life Plaza, 1100 Melville Street, Vancouver, B.C. V6E 4A6
Tel:(604) 685-0275 Fax:(604) 684-6241 Email: kholm@eba.ca
InsPark (inspark@aol.com) wrote:
: My Pashley seat is falling apart and I want to replace it with a Viscount,
: available from DM unicycles. However this requires a different seat post to
: the original and he asked me if the Pashley is 25mm or 1 inch diameter. I do
: not have a micrometer and it is difficult to judge with a tape measure! Does
: anybody know the answer? My Muni is a current model, only about 4 months old.
Jerry
Have you had a look at your existing seat post? I’m fairly certain that my old
one had it stamped on there somewhere - probably by the limit mark.
Paul Selwood paul@vimes.u-net.com
Yes. There’s very little movement in a seat-post clamp. The three sizes of
seat-posts are a right pain in the, well, wherever.
The symptom of a mis-matched seatpost/clamp is that even if you do it up tight
it still creeps. This is because it will be clamping at a point, which wears
into the post, rather than on concentric faces.
You can shim with a slice cut from a coke can (or similar), which is easy and
cheap, though be careful you don’t cut yourself with the edge of the shim - it
makes a nasty ragged cut. Decent kitchen scissors will cut a drinks can (though
how long they remain decent if you do it repeatedly is probably debatable).
regards, Ian SMith
|\ /| Opinions expressed in this post are my own, and do
|o o| not reflect the views of Amos, my mbu puffer fish.
|/ | (His view is that small snails are very tasty.)
Amos now on the web at http://www.achrn.demon.co.uk/amos.html
> > do not have a micrometer and it is difficult to judge with a tape measure!
> > Does anybody know the answer? My Muni is a current model, only about 4
> > months old.
Be warned the 0.4 will make a massive difference and will not clamp properly at
that difference.
There are 3 sizes fitted to pashley unicycles, none as far as I know are 25 or
25.4. The Muni’s have a 25.8. If you pull it all the way out I believe it is
stamped on the bottom section.
Roger
In article <36F03058.98AF7509@Octacon.Co.Uk>, Roger.Davies@octacon.co.uk (Roger
Davies) writes:
>stamped on the bottom section.>
Thank you professor, the best solutions are usually the simplest… :slight_smile: I pulled
it all the way out and it did indeed have 25.0 stamped on it. I am now back in
action with a new seatpost and lovely YELLOW saddle!
BTW do not attempt to repair a Pashley saddle with an arc welder - the foam
inside melted away to nothing leaving a large cavity!
Jerry Cooper
–WebTV-Mail-283970635-391 Content-Type: Text/Plain; Charset=US-ASCII
Content-Transfer-Encoding: 7Bit
If it’s of any help, the way that I solved my Pashley Muni seat problem was to
cut the seat mounting bracket off of the post and then weld a Viscoun/Schwinn
seat bracket (previously cut from an old Schwinn post) onto the Pashley seat
post. This is the only real true way to solve the problem. Do not try to shim,
or clamp a smaller OD post onto the unicycle as it will distort, bend, break, or
(if nothing else) rotate too easily when turning. This was a very clean
modification (looked good), was easy to do, and is very strong. Anybody with a
wire feed welder can do the job if you don’t have access to one. Mike Payne
–WebTV-Mail-283970635-391 Content-Disposition: Inline Content-Type:
Message/RFC822 Content-Transfer-Encoding: 7Bit
Received: from mailsorter-101.iap.bryant.webtv.net (209.240.198.91) by
postoffice-142.iap.bryant.webtv.net; Wed, 17 Mar 1999 15:27:02 -0800 (PST)
Return-Path: <unicycling-owner@icicle.winternet.com> Received: from
icicle.winternet.com (icicle.winternet.com [198.174.169.13]) by
mailsorter-101.iap.bryant.webtv.net (8.8.8/ms.graham.14Aug97) with ESMTP id
PAA18722; Wed, 17 Mar 1999 15:26:55 -0800 (PST) Received: (from
server@localhost) by icicle.winternet.com (8.8.8/8.8.8) id RAA12647 for
unicycling-outgoing; Wed, 17 Mar 1999 17:20:14 -0600 (CST)
X-Authentication-Warning: icicle.winternet.com: server set sender to
owner-unicycling using -f Received: (from adm@localhost) by icicle.winternet.com
(8.8.8/8.8.8) id RAA12494 for <unicycling@winternet.com>; Wed, 17 Mar 1999
17:19:34 -0600 (CST) Received: from goole.octacon.co.uk(193.118.80.1) by
icicle.winternet.com via smap (V2.0) id xma012465; Wed, 17 Mar 99 17:19:12 -0600
Received: from Octacon.Co.Uk (p04-45.onyx.net [194.176.69.109]) by
goole.octacon.co.uk (8.9.0/8.9.0) with ESMTP id XAA01395 for
<unicycling@winternet.com>; Wed, 17 Mar 1999 23:19:13 GMT Message-ID:
<36F03058.98AF7509@Octacon.Co.Uk> Date: Wed, 17 Mar 1999 22:44:40 +0000 From:
Roger Davies <Roger.Davies@octacon.co.uk> X-Mailer: Mozilla 4.5 [en] (Win98; I)
X-Accept-Language: en MIME-Version: 1.0 To: “unicycling@winternet.com
<unicycling@winternet.com> Subject: Re: Pashley seat post References:
<19990316152354.26272.00000065@ngol08.aol.com> <36EECEC9.3C3D@eup.k12.mi.us>
Content-Type: text/plain; charset=us-ascii Content-Transfer-Encoding: 7bit
Sender: owner-unicycling@winternet.com Precedence: bulk Reply-To: Roger Davies
> > months old.
that difference.
Roger
–WebTV-Mail-283970635-391–
