i hope so…
Im in too I suppose XD
They are both converting so you cant see vimeo yet and youtube will have bad quality for a bit ![]()
youtube:
Vimeo:http://vimeo.com/7113967
Trick 1: 30 idles, Set by Trevor
Trick 2: Will be set by Julia on Friday
_ _ _Trevor Stader* (set)
_ _ _96erik (landed)
_ _ _Julia B (landed)
_ _ _Xyphota
_ _ _Anton005
_ _ _SirSkillz
_ _ _Cubemansam
_ _ _The Defecator (landed)
_ _ _Crosseyed
_ _ _Molehill (landed)
Anton has landed too
My bad. I copied it from an old post and forgot to update everything.
_ _ _Xyphota
_ _ _Anton005 (landed)
_ _ _SirSkillz
_ _ _Cubemansam
_ _ _Crosseyed
I think I might join when i figure out how to get the video on
I was wondering if I could do it on my giraffe because I find it easier to idle with it.
Haha, I suppose you could do it on your giraffe if its a 20"
Someone else will no for sure.
i may join. ive been working on my idling and i got 29!! just need to shoot for 30! i will see.
Good work. ![]()
You will get it Ill put you on the list. ![]()
_ _ _Xyphota
_ _ _SirSkillz
_ _ _Cubemansam (landed)
_ _ _Crosseyed
_ _ _Unicyclingisfun
ok. i may not get it though. i will try
If you cant get it it doesnt matter it just means youll get a O
you should be able to get it by friday easy. ![]()
The pnly problem is you said you dont like being infront of the camera so you are just going to have to get over it
Good luck.
I guess im playing.
Here it is. Lost count so i think i did at least 30, if not let me know and I will be glad to do it again.
Good work. ![]()
_ _ _Xyphota
_ _ _SirSkillz
_ _ _Crosseyed
_ _ _Unicycle Person (landed)
i can only get like 3 idles and then fall off.
any tips?
I got it…
http://www.vimeo.com/7134535
My hand didn’t touch the telephone pole. I picked a bad angle, but you’ll have to trust me.![]()
Learn to ride backwards. It helped me a lot.![]()
_ _ _Xyphota
_ _ _SirSkillz (landed)
_ _ _Crosseyed
[QUOTE=
Learn to ride backwards. It helped me a lot.:D[/QUOTE]
I can ride backwards. not the most perfect, but still can ![]()
When I lernt try to get off your seat and do it standing up sorta thing if that makes sence irs not the right way to do it though but it worked. ![]()
Good Luck with it. ![]()
