Opening Pedals?
When I got my Torker LX-20, it came with Wellgo LU985 (K79) pedals (cheap plastic) which are starting to click. I want to adjust them, but I can’t tell if these pedals can even be opened. Does anyone know?
I had the same problem. Buy a new set of pedals, i wouldn’t waste my time with them.
To take apart pedals you need to take off the cap at the end of the pedal, then unscrew the series of nuts under the cap. Once you have done this the axle will slide out of the pedal body.
Yes! They can be opened up and adjusted. I just did it with mine after seeing this post. Just use a small jewelers style screw driver to remove the cap.
