RE: Now you can get a Pashley
> Give me specific details of problems with current Pashley MUni and I will do
> what is required to get them improved.
Is that Duncan Castling? Do you have the ear of the guys at Pashley? Cool.
> I know the saddle’s crap I’ve got the scars to prove it, tell me more…
More like what? Like it’s really really crap? If they’re actually
manufacturing their own seat, it would help to make it smaller, more similar in
shape to a Viscount or Miyata seat, but not round across the top to interfere
with our circulation. Also try to eliminate whatever is causing your scars and
Beirne’s sore spots. This might be from too much width and hard foam.
Better yet, start over and build the world’s best air seat! A strong cover
over a space for an innertube. Bumpers or hard foam to protect from drops.
The old-fashioned tilt adjuster should go too. Miyata and many other brand
seats have no tilt adjustment but I never hear people complaining about that
fact on them…
> the current seat clamp is alloy BMX with Allen key- what’s wrong with that?
Fine with me. I always need a very powerful clamp, because my seat gets a lot of
twisting force on it. It’s very hard to find a quick release clamp that’s even
close to strong enough. Besides, quick release should be an aftermarket addition
for a MUni, which in most cases is probably ridden by one primary person. Quick
release is more useful on a learning machine.
> I thought the 26" Camel MUni tire was fine , but have changed my mind- I’m
> still looking for a centre ridge tire with good mud paddles on the side -
Where we ride, tires wear out relatively fast. The best MUni tire I’ve had so
far was great until the sidewall blew out. I would still use that tire if I can
get another one because it had a tread that rode good on dirt & pavement, and
had plenty of tread but not too much. It was a great compromise for my type of
riding, but tire choice is a very personal thing and depends on where you ride.
I wouldn’t worry too much about tires.
But I usually don’t like tires with center ridges. It depends on the size/shape
of the ridge, but they usually don’t work well for me on hard ground.
> (Constructive criticism always welcome)
The bearing attachment method is primitive. If the uni does not come with
washers to interface between the round tubing and the flat washers, they are a
must. Brett Bymaster says the tubing is tapered where the bearing attaches, for
a poor fit that probably stresses the tubing. Another possibility for this area
is to use two seat post clamps instead of all the bolts.
Enjoy, John Foss, the Uni-Cyclone happy on my Roger Davies Carbon
http://www.unicycling.com
