Tell your brother he’s a dumbass, then smack him upside the head.
Cotterless is square taper, and are 3 piece cranks.
3 piece simply means you have to attach the cranks to the spindle (or whatever people call it these days) the only alternative to 3 piece cranks is 1 piece cranks, which is kind of just a bent piece of metal, with threads at each end for pedals.
I would say (like most other people) that you should get the nimbus and buy a KH moment hub. You are way to good for square post cranks! The KH hub will fit a nimbus frame. Cody rode a 42mm koxx wheel on his 40mm torker frame. TimBob has a KH frame with a Koxx wheelset. My brother has a Koxx wheelset in a Nimbus 2 frame. They are all completely inercompatable.
Hope that helped.
so your saying the kh hub will fit on the nimbus
cos i dont really understand how this would fit on and how the cranks would go on it
cos the ends look too big for cranks to go on
If you mean “will my nimbus cranks fit on the KH hub?” the answer is NO.
The KH is ISIS, the nimbus is square taper. You need to get the whole hub assembly, and trust me, It will fit:).
If you are getting the 48 spoke nimbus, you have a problem as the KH hub is 36 spoke.
once i get my unicycle Reef and i get good enough i will ask my uncle to ask rodney “the guy who organises the entertainment at the crocs games” to let us do a half time show or somethink and that will be were we will make alot of money.
Sorry, couldn’t be fucked reading every reply. But, so far my nimbus has done okay, though I’m a bit of a pussy on the 'ol unis so maybe i havent given it a thrashing yet.
I will say that Max (max_pheipher) told me that they have pretty weak cranks that’ll bend easily. Maybe you should go for an ISIS Trials like him. Oh that’s right, NOT ALL OF US ARE SPONSERED AND CAN BUY $800 FUCKING UNICYCLES MAX!
lawl but seriously get a nimbus, give it a walloping, then return it and say it was a defect. Then ask for the movie defect.
