Nimbus 36" Impulse - Disk Brake
Selling due to lack of use. Has been stored in a dry garage for 3 years and is in a great condition (see minor wear and tear in photos and below)
See more photos here: https://www.gumtree.com/p/bicycles/nimbus-36quot-impulse-unicycle-disk-brake/1312461877
Only ridden a couple of times.
Item located in Derby but can meet in Birmingham or Gloucestershire as I travel regularly with work.
Saddle: Nimbus gel (black)
Seat post: Nimbus 25.4 x 250lg Pivotal Seat Post (has been cut down due to shorter rider)
Saddle: Nimbus Shadow handle base
Handle A: Nimbus Shadow T-handle, bent, 400mm long (non bent handle included)
Bar ends: Nimbus Shadow Bar ends, 130mm long (slight damage with scuffs)
Frame: Nimbus 36" Impulse Disc version of the Nightrider
Hub/axle: Nimbus ISIS drive LT Disc (black/green) 36H, 7075 series aluminum splindle,128mm center bearing to center bearing
Spokes: 14G. stainless (372mm in length for 3X) brass nipples
Rim: Nimbus stealth1 36 18mm lightening holes, 42mm wide, aluminum doublewall, reinforced eyelets, ERD-767mm
Tire: Nimbus Nightrider 36" x 2.25" multi surface
Crank arms: Nimbus 125/, ISIS splined, aluminum (slight damage to one crank bolt)
Pedals: Nimbus, reinforced plastic body with steel removable pins, backing plate for added durability and CrMo axle with 9/16 threads
Bearings: 22mm x 42mm x 12mm
Brakes: Bengal Helix 1.1 hydraulic brake with 160mm disc
