I have a few sets of new and lightly used Magura HS33 rim brakes left here: black, silver, yellow and red. Its gotten really hard to find these anymore and I’m kind of moving on to other bike projects - so I’m pricing the remaining ones to move. . .
$70/wheel for a lightly used brake
$120/wheel for a new (New old stock) brake
Brake lever blades are all KH Starfighter/spooner compatible. Brakes come set up with black brake pads and whatever line length you want (I can calculate line length for you if you want me to) a longer unicycle-ready 10" crossover tube l, bled and tested for leaks and function. Comes with mounting/adjustment instructions I wrote up for unicycles.
Brakes will fit on any Kris Holm or any brand of unicycle (Hunter, Nimbus, etc) that comes with dedicated four-bolt Magura mounts on the frame legs.
PAYMENT AND SHIPPING:Paypal works best for me. My paypal address is: uniflasher@gmail.com. Shipping will be $8 for USPS Priority Mail shipping in the US (2-3 days) and $15 for first class shipping to Canada (7-9 days). I ship the day after I receive funds.
BLEEDING / TESTING:
I flush and bleed all brakes with fresh Magura blue blood before I test for leaks by putting the wheel cylinders into a custom test jig that I made. There, I’ll cycle the brake pistons under full braking power to check for proper function and leaks without having to bolt them up to a unicycle frame.
[B]* Under saddle lever mounts
- New Magura four bolt mounts with stainless hardware
- Magura rim brake bleed kits
- Misc. Magura fittings and parts
Cheers,
Brycer1968
503-358-2252
uniflasher@gmail.com [/B]
Pics for LargeEddie
See personal message for more information.
PM sent
PM sent concerning Nimbus 29er
Just sent PM reply.
Cheers,
Bryce
School Bus Yellow
Got my brakes and got them installed. They are really cool and the perfect length. The condition was better than he described. It was a pleasure talking with Brycer to get the configuration perfect. If you have any Magura needs (before Brycer runs out of them completely:() you should contact him.
Thanks again Bryce,
Kelly O’
Does the price include the lever mount and the brackets?
Email sent.
Hi Chad. The $70 price does not include the under saddle bracket for the lever or the four bolt Magura mounts, though I have both of these items new here as well. Just sent you a message too.
Cheers,
Bryce
Pics for the Max and or Chad
See PM for more info. This brake is the only red/black one I have now, its new (NOS).
Pics for MAX and Chad
Used silver brake that will come with black brake pads( not shown).
Used silver/black brake for Chad and Max
lightly used silver lever with black slave cylinders.
This lever has a damaged bleed port that I milled off the damaged section so it can be bled, but the bleed port still has a hairline crack that doesn’t effect its usability or strength. The slave cylinders have cosmetic boot polishing that removes some of the finish, but they still work great.
This brake is a bargain because of the crack. See PM
Bump. I still have a couple of HS33 brakes left and loads of parts. Let me know what you are looking for.
Cheers,
Bryce
Any Frankenbrakes left? Or even just the HS-22 Lever/master cylinder?
Magura for a Nimbus 29" Muni
I have a 29er in the mail and would like a brake set up to install when or soon after it shows. Do you still have some left? do you have any in black?
thanks
Mack
Sure. I can set you up with that. I left a VM for you. Feel free to text/call to discuss options.
Cheers,
Bryce
503-358-2252
Do you have any more HS33 brakes left? I’m looking for one for a 26" mUni.
Thats about it for the used HS33’s
Although I have several years worth of parts/supplies here for any HS33 rim brake, I just sold the last used HS33 I have here, so now I have just the new NOS (new old stock) HS33’s here, which i photographed in another thread in the trading post. I also have a couple of the HS33/22 Frankenbrakes here too for 36er wheels
Feel free to contact me if you need parts, line, bleed kits, fittings, etc
I’m also here for ya if you have questions about / problems with your hydraulic rim brakes
Cheers,
Bryce
cell/text
Frame boss for Magura brakes
Bryce - -
I would like to add frame bosses to a uni that does not currently have them. Do you have any of the bosses available for sale? If so, I would like a set. Please send availability and pricing info.
Thanks,
Kelly O’ a.k.a. pkbjamn
HI Kelly. I have the stamped steel bosses made by Magura that can be TIG welded or brazed onto steel unicycle frames. They won’t cost you much. How about $8 shipped.
PM me if that sounds like what you need.
Cheers,
Bryce
