New Magura HS33 Olympia limited edition brakes and loads of other NOS Maggie rim brakes too.
I’m sorting through a large lot of new old stock (NOS) Magura rim brake parts I picked up recently. The pictures show just a portion of the NOS stuff I picked up.
I started putting them together into sets for unicycles. Lots of colors from day-glo yellow to red to booring old silver and black. Comes with new black brake pads, brake line length and crossover lengths of your choice and I bleed and test them before I ship so they will be ready to mount on your unicycle right out of the box. All of these lever blades are KH spooner compatible.
These brakes will fit on any Kris Holm unicycle: 20, 24, 29 and 36 or any brand of unicycle (Hunter, Nimbus, etc) that comes with dedicated four-bolt Magura mounts that look like this: http://www.inspiredbicycles.com/images/frame-brown-mounts.jpg
You will need Magura four bolt mounts like this (I have a few sets of these too): http://www.unicycle.com/unicycle-hardware/brakes/magura-mounting-brackets.html
You will also need a place to mount your brake lever under the saddle like this: Kris Holm Brake Mount | Unicycle.com
[B]PRICES (for new HS33’s assembled from all new/NOS parts):
- 2004 HS33 Olympia limited edition brake, three of these with pimpin’ gold lever blades: $100 per wheel
- 2004 HS33 Red, silver, yellow, black and blue levers with matching cylinders: $95 per wheel
- 2005 HS33 black and silver newer style levers with matching wheel cylinders: $95 per wheel
- 2004 HS33 levers with choice of new, but non-matching wheel cylinders: $90 per wheel. Mix and match what ever color combination you want.
PAYMENT AND SHIPPING:
Paypal works best for me, but money orders are also ok. My paypal address is: uniflasher@hotmail.com. Shipping will be $5 for USPS Priority Mail shipping in the US (2-3 days) and $10 for first class shipping to Canada (7-9 days). I ship the day after I receive funds.
BRAKE LINE LENGTH:
I’ll set up your brake with whatever length of brake line you want from 18" on up to some freaky long distance handlebar at 30" or more. If you want, I can also help you determine the right length of brake line for your leg length and unicycle wheel size. Just ask. I also change the cross over tube to a longer 10" line that clears 3.0" tires better.
BLEEDING / TESTING:
I flush and bleed all brakes with fresh Magura blue blood before I test, pack and ship your brake. Bleeding hydraulic brakes is messy and no fun - and so you won’t have to deal with fluid leaks, after I assemble and bleed them with fresh Magura blue blood, I test them all for leaks by putting the wheel cylinders into a custom test jig that I made. There, I’ll cycle the brake pistons under full power to check for proper function and leaks without having to bolt them up to a unicycle frame.
MORE BRAKES AND PARTS:
I also have six sets of lightly used genuine Magura alloy four bolt mounts with new stainless steel hardware for $18 per wheel, some stainless braided brake line kits, bleed kits and loads of other Magura rim brake stuff, new and used.
E-mail me if you want something different or digital pictures of something in particular. I also have a good selection of less expensive nice used HS33 and HS22 brakes and several of my HS33/HS22 hybrid “franken-brakes” for 36” wheels too.
Cheers,
Brycer1968
503-358-2252
