$90 per wheel, plus shipping
I have four sets of Brand new NOS Magura HS33 hydraulic brakes in this great blue color that is a really close color match to modern Kris Holm blue. These have the old style (Pre-2005) lever. It’s getting hard to find forgotten stashes of these out there in new condition AND in Kris Holm Blue.
HS33’s are the gold-standard brake for Maggies on your unicycle. The red adjustment wheel on the lever lets you dial in the distance between the brake pads and the rim –on the fly, as you ride. They will fit on any KH unicycle: 20, 24, 29 and 36 or any unicycle or bike that has dedicated four bolt magura brake mounting lugs like this: http://www.inspiredbicycles.com/images/frame-brown-mounts.jpg and you’ll need to have a place to mount a lever under your saddle like this: http://www.unicycle.com/shopping/shopexd.asp?id=908
Comes with NOS Magura black or red brake pads. Your choice.
Included in this price is my cutting and installing any length of brake line you specify, from 16-23” long (18” is standard length) . And then I’ll fill it with Magura blue blood and bleed it for you before I pack and ship it. Bleeding hydraulic brakes is messy and no fun and so you won’t have to deal with fluid leaks, after I assemble and bleed them, I test them all for leaks by putting the wheel cylinders into a test jig that I made. There, I’ll cycle the brake pistons under full power without having to bolt them up to a unicycle frame.
Comes with what you see in the pictures, so you will still need to get a set of Magura four bolt brake mounts like this : http://www.unicycle.com/shopping/shopexd.asp?id=907 or maybe you are wanting something more pimpin’ like these nicer mounts that come in blue http://www.trials-uk.co.uk/files/ecomproducts-image-1571.jpg to mount the brake on your unicycle.
$90 for a brake for one wheel, plus shipping from Portland, OR (usually $5-$8 for priority mail to most US addresses). I’m also OK shipping to Canada and have found the USPS first class international rate to be a good deal and they deliver in about 7-10 days or so.
Paypal works best for me.
Let me know if you have any questions and see my other postings if you want to save a couple of bucks and go with used Maggie brakes, I’ll have an assortment of both used HS22 and HS33’s up on here soon.
Brycer1968
