Thanks for the review.
Can you send me a closeup photo of the torn buttonhole for the bolt? Send to kris at krisholm.com - thx.
Conventional Pivotal saddles have a slotted rubber piece for this hole. However, the existing design does not work well with a cutaway and is designed for use without a cutaway. I felt it would be uncomfortable (e.g. you’d notice it when sitting). Perhaps the manufacturer can keep the sewn buttonhole but add a laminated backing to the fabric so it does not tear. Will look into this.
Re weight and foam: I’m similarly lightweight: 1.8 m, 65 kg. I also agree with you that a heavier rider will compress the foam further - hence the need to make sure the foam is either firm enough (for the existing foam thickness) or thicker/bulkier. Offroad I am finding the existing foam has better shock absorbancy than a tester prototype I have with softer foam, again because in the latter case I bottom out the foam on an impact.
Kris
