I have a new QU AX muni 24" with 3.0 tire what amount of air pressure are you guys running off road? and are you lowering your seat height from normal street riding? and if so how much lower?
Thanks
Robert
This is just something you’re gonna have to experiment and find out what suits you. Try different things, and see what you like, and what doesn’t work for you.
Re: Muni Questions?
Depends on your weight, style and personal preference. It should be
squishy to absorb stuff, and provide some ‘spring’ when jumping, But
if it folds sideways when making a sharpish turn it’s too low. Also if
you drop and the rim hits the ground (through the tyre).
Yes you lower it. Again, preference and style dependent. You lower it
more if for hopping you rely on seat-in. Try lowering 4 inches as a
starting value. If you’re not used to riding that low, go in steps.
For climbing, however, a low seat is disadvantageous. Some (but not
many) people use a quick release seat clamp and increase seat height
just before a long climb.
Klaas Bil - Newsgroup Addict
“dit dit diddle diddle dit dit did-it, dit dit diddle diddle dit dit did-it, dit diddle dit dit dit diddle dit dit, diddle-diddle-diddle-diddle-dit dit diddle diddle dit dit did-it,… - Spudman”
