Muni: Nimbus/QU-AX/Mad4One
Hi @JH33,
The good news is that type of topic has been discussed in the past so if you havr some time to read more about it, here are other topics related:
(That is just a selection for about 1 year ago but there are slightly older threads that will givd you extra opinion to consider: Search results for 'muni size 24 order:latest' - Unicyclist.com)
It’s always difficult to recommend anything not knowing the rider and the intended terrain. I will try and guess based on what you wrote.
For starting, a steel frame is a good choice and all are good enough so the difference between the good brands is minimal. As has been stated: disc ready is ideal although post-upgrade is possible (if not the D’Brake adapter is OK but not ideal).
Wheel size: I think 26 to 36 is the size range for XC and 24-29 for Downhill (I ride 29+ DH and 29/36 XC). 24 is for small riders or very technical riding with trials-like hopping.
Even with short cranks like 100mm, a 24" is just no fun for commuting anything over about a mile.
As to 26/27.5/29, the difference isn’t huge. 26 is great for learning but the tire selection is getting worse…
I think with a 27.5 you’re probably good (assuming you can already ride a little, for the first time it’s quite big).
Maybe also look at finding a used 26".
If you want to do muni and also commute around town, I would consider dual/triple hole cranks (I ride them almost exclusively on my 4 >24 unis), e.g. 110/136 or 127/150 if you want longer (I like short cranks but that takes getting used to). For starting the VCX 100/125/150 are OK, although with time I find the range too big (I like 110s and 136 better), but good on my 36. Most dealers will let you pay the price difference.
Oh, 24" is also good for learning muni. After a bit you will want to go bigger.
I just ordered a Nimbus Muni 24 with the 100/125/150 cranks. I decided I wanted to prioritize learning(both muni and general skills) for the time being and I can still certainly get around. My campus is maybe half a mile across(but it is a hill), so distance is fine. I figure that it will treat me well as I learn and progress and last me until I can properly excuse expanding my stable.
