Re: Mounting on hills and other questions
Thanks all for the advice. I will add the static mount to the top of my list of mounts
to practice. I have seen other people do it, but always found it looked awkward,
compared to the graceful swan-like movement of the rollback mount.
I guess there is more subtlety to this. Going downhill, you would have to start with the
weak foot on the back pedal, the opposite for uphill. Yet, in a steep uphill, you couldn`t possibly
jump over the uni, so maybe a backward rollfront mount would be more appropriate… Anyway,
I will try variations of this this coming weekend. Thanks for the lead.
As for the jump mount (suicide mount?), this looks like something I should not be interested in
until I invested in a full body armor, yet, in a masochistic way, I can`t stop thinking about it!
Just FYI, I use a 24" Torker unistar.
Thanks,
Jocelyn
“onewheeldave” <onewheeldave.qc1mz@timelimit.unicyclist.com> wrote in message news:onewheeldave.qc1mz@timelimit.unicyclist.com…
> I’ll be brief cos I’m sure you’ll get lots of replies om this.
> 1-Going up and down hills is a fun challenge, but usually results in
> joyful
> UPDs. How do you mount in the middle of a hill (up and down)?
> If you’re not doing so already use a ‘jump’ mount rather than a ‘roll
> back’ mount. roll back is the standard hop on do 1/2 pedal back and then
> ride.
> jump mount is to put first foot on pedal than jump onto second pedal
> whilst putting no weight on the first one (so the cranks don’t move from
> their initial horizontal position). Much better for mounting uphill.
> Another option is to mount facing at an angle to the slope.
> 2-Idling: I find, very frustratingly, that using both methods I read
> about
> (ride, slow down, ride backward, resume forward riding and hold on to
> something and idle on) I am making absolutely no progress whatsoever
> and
> this skill seems absolutely impossible to learn. Any encouragement?
> I spent ages holding onto a wall with little progress. Then forced
> myself into the open and started to get better.
> Try mounting in the open with a roll back mount then roll forward 1/2
> rev, back 1/2 rev etc. etc.
> Try it in a field so it’s better to fall in.
> 3-Saddle soreness. I rode for about 1h30 at once last weekend and my
> butt
> is sore in a way that I wouldn’t dare describe (at least publicly…).
> How
> can you ride longer without permanent disability?
> there’s been loads of posts on this subject!
> Airseat, cycle shorts, talcum powder are the main solutions.
> 4-Mounts usually result in a 90 to 180 degree turn, which is quite
> annoying
> in a narrow trail. How do you avoid this pivoting while mounting?
> Practice will eliminate this over the next few weeks
> Otherwise, I am happy to report that I can go down curbs, magically
> managed
> the side mount foot in front a few times (scarier then other 2
> mounts…)
> and can imagine some day being able to mount from the other foot (would
> you
> recommend practising this early on?). Hopping and going up curb is on
> the
> practise list, but sofar no other progress then a few embarrasing
> injuries.
> Sounds like you’re doing really well. Practicing mounting with the other
> foot is a good idea, though I still haven’t learnt it. You should
> practice what you feel like practicing.
> It’d be useful if you gave more info such as which type of mount you’re
> using, what kind of unicycle i.e. 20"-er, Muni with big tyre etc, as
> this will enable people to give you more relevant advice.
> onewheeldave - Semi Skilled Unicyclist
> “He’s also been known to indulge in a spot of flame juggling - but it’s
> the Muni that really fires him up.”
> onewheeldave’s Profile: http://www.unicyclist.com/profile/874
> View this thread: http://www.unicyclist.com/thread/26622
