Hi,
I’d like to know if there is a particular name for the screws used to attach the magura brake mounts to a KH frame (or any other I guess). I’ve stripped the top bit of the thread on my frame, but if I could find a longer screw I think it will tighten up OK again.
Thanks,
I’m assuming the standard socket head cap screws that go on the 4-bolt mount? It should be M5x22mm or 25mm depending on the frame (at least for bike frames). Pitch is 0.8
Brilliant, thanks for your help. I measured the screws I have as around 20mm (didnt included the head of the screw). Have ordered a couple of longer lengths, hopefully will do the trick.
Cheers
Dan
