Hey,
Shortly, you may be able to get a low end fork to fit your high end wheel hopes. Not being able to shell out the $1000+ that a high end ride would set me back, I waited on a frame to come from Tiawan via The UK Source that would fit a Profile/Gazz set up. I started riding again in September after a 11 year hiayatus- and now am on my 2nd rim, hub and 3rd set of cranks. This last set of cranks began to die on a road trip to Memphis. Pounding cranks back on when you’re 300 miles away from home is not fun; it was time to bite the bullet and buy a Profile.
The fork is what Rodger at the UK Source calles a “Nimbus II” (after a frame that bears no resembalance to it’s predisessor)- but looks like a Devil’s fork- I’ll call it the ‘Lucifer’ (name like that has sex appeal, ya know? I’ll leave the Nimbus for young wizards and the like). I’m not sure what they are going to end up costing- but I susspect it will be less than $60- maybe a good deal less. As you may have seen, the fork has a pronounced barb at the crown, which is reputed to be a cozy place to rest your foot; I wouldn’t know about that- but it does look hell-a-cool. More importantly, it will acomodate a 3" Gazzoloddi with little less than 1 cm clearance on each side. This will meen occasional ‘Ping!’'s from stones picked up by the tread- but if you get a tall enough fork you should be able safely vise the down tubes and get a little more room. As is, is ok. There is oooodles of room for a tire like, say… a Fireball (if you can lay your hands on one). The frame is nice and stiff and hasn’t allowed even a hint of wheel rub- and this is with the 28" frame. Weight considerations aside, I actualy prefer the way it responds compared to the Hunter or Wilder.
I wedd to this an Alex DX 32 rim- at half the cost of the Doublwide and only a very margenal difference in pinch flat resistance, a no brainer. The Alex is acutaly made from a harder aluminum alloy that reputes a greater resistance to developing flat spots, features a CNC machined breaking serface- and is lighter. Add the $40 saved going with this rim over the Sun to the the frame choice, and your pocket book is heavyer by at least $400.
Untill the doctor cuts me loose, I won’t be able to post a proper performance review; however (much to my detriment) I have put a couple hours urban riding in. While the added weight of the Profile and Gazzoloddi is not negligable, the volume of the tire more than makes up for this in the hop, and I sure feel better having the high volume tire under me on the way back down a flight of steps (the benifits and cons of this set up have been well address elseware, nuff said). I can’t let the Dyno Fireball neer the Lucifer untill my head’s screwed back on straight- when it is, I’ll let you know if it was worth the deal with the Devil.
So, a parital cost break down:
3 x 24" Gazzoloddi: $45
Alex DX 32 rim: $40
Nokian Downhill tube: $9
Profile Hub and Cranks: $315
Viscount Sadle: $20
United Seat Post: $9
Seat Post Clamp: $4
Odyssey Twist Pro Pedals: $24
Frame: ??? $50 ???
Spokes and Wheel build: ???
Maybe around the mid to high $500’s to put yourself on a serviceable 3" Profile/Gazz wheel, with the ability to upgrade componants later as you see fit. For my pocket book, this was the way to go.
Check out more photo’s in the Unicyclist.com Gallery, here:
Christopher
