Looking for Qu-Ax 125/145mm Q-Axle cranks - USA
Please fill in the Add Location field above before posting your ad.
Since people here live all around the world, this is mandatory information.
SOLD - en route
I currently ride 145mm single hole cranks which I really like for muni, but I’d like dual hole cranks for more options when munipacking.
UDC has KH Boundary cranks with holes both longer and shorter that I could get in a pinch, but I’d prefer to stick with the longer length that I am familiar with.
Anyone in the USA have a pair they’d like to sell?
Anyone coming to the USA in the next few months from Europe who would be prepared to get a pair for me?
Thanks in advance
It may not be the most economical solution, but I believe @jaco_flans can drill your cranks to the length you want.
Thanks for the idea. While possible, it’s not ideal as the Qu-Ax single hole cranks are I-beam shaped, i.e. dished on both the inside and outside surfaces between the existing holes, meaning it would be hard to get a flat surface for the pedal or insert to bottom against, and not much section for the threads.
https://www.goudurix.com/en/cranks-q-axle/
Your size seems to be in stock.
I ordered from this shop once in 2023. There were some issues with my payment method, but the seller resolved it successfully.
Thanks for the info. I didn’t know about this shop.
Maksym very kindly brought over a pair of cranks for me. They are currently en route. I didn’t want to update the post to resolved until I actually have them in hand.
